Philips Hue Devere Medium Ceiling Lamp - White
Quicklinx: GVRDWS00 Mfr#: 915005997601
Get powerful, warm-to-cool white light in the bathroom with the medium Devere ceiling light in white. Brighten the room to apply makeup or get ready for work in the morning - or dim down low for a relaxing soak in the bath.
  • Set the mood with warm-to-cool white smart lights
    Choose from over 50,000 shades of warm-to-cool white light to create the perfect ambiance in your bathroom for each activity and time of day. Use bright, white light each morning to start the day energized and alert, or match your evening wind-down routine with a dim golden glow.
  • Optimized light recipes for your daily activities
    Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light.
  • Get installation-free dimming straight out of the box
    Use the Hue dimmer switch to get instant control over your Philips Hue smart lights. With the touch of a button, anyone in the house can instantly dim or brighten the room, turn lights on and off, or set light scenes.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Set up hands-free voice control
    Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands.
  • Unlock full suite of smart light features with Hue Bridge
    Add a Hue Bridge (sold separately) to your smart lights to experience the full suite of Philips Hue features. With a Hue Bridge, you can add up to 50 smart lights to control throughout your home. Create routines to automate your entire smart home lighting setup. Control your lights while away from home or add accessories such as motion sensors and smart switches.
Philips Hue White ambiance Devere M - ceiling lamp - LED - 19.2 W - warm to cool white light - 2200-6500 K - white
Ceiling lamp
Recommended For
Bathroom
Light Source Type
LED
Style
Modern
Light Cover Type
Diffuser
Dimmer
White
Wattage
19.2 W
Energy Efficiency Class
F
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
1900 - 2450 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue, Nest, Echo
Communications Technology
Bluetooth
Frequency Required
50 - 60 Hz
Ceiling lamp
Recommended For
Bathroom
Style
Modern
Light Cover Type
Diffuser
Dimmer
Waterproof
Protection class I, controlled via Bluetooth, app-controlled, power on/off timer, voice control
Light Source
LED
Built-in LED Lamp
Wattage
19.2 W
F
Colour Temperature
2200-6500 K
Luminous Power
1900 - 2450 lumens
Lifetime
25000 hours
Power Requirements
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue, Nest, Echo
Compatible Application
Philips Hue App
Bluetooth
Product Material
Metal, synthetics
Body Colour
White
Dimmer switch
Package
Box
IP44
Warranty
2 years / 60 days return
8.4 cm
Diameter
38.1 cm
2.589 kg
43.7 cm x 45.7 cm x 10 cm / 3.389 kg
