Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp. -
Create a personalized experience with colorful smart light
Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more. -
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs. -
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
- Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - E27 - 9 W - 16 million colours/warm to cool white light - 2000-6500 K - white (pack of 2)
- Light Source Type
- LED light bulb
- Packaged Quantity
- 2 (specifications are for single item)
- White
- Shape
- A60
- Socket Type
- E27
- Wattage
- 9 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 806 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Nest, Echo
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 9 W
- 60 W
- F
- Energy Consumption per 1000h
- 9 kWh
- Power Factor
- 0.8
- 2000-6500 K
- Luminous Power
- 806 lumens
- Warm-Up Time
- 0.5 sec
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- ZigBee technology, instant full light, Android compatible, iOS compatible, indoor usage, voice control, app-controlled, 16 million changeable colours, controlled via Bluetooth, preset modes
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Body Colour
- White
- Package
- Hanging box
- Warranty
- 2 years
- 6 cm
- 6 cm
- 11 cm
- Diameter
- 60 mm
- Length
- 110 mm
- 144 g
- Shipping Dimensions (WxDxH) / Weight
- 14 cm x 7 cm x 16.5 cm / 224 g
- -10 °C
- 45 °C
