Philips Hue Colour Bulb 9W A60 E27 2-Pack
Quicklinx: GSLXWS00 Mfr#: 929002468802
Discover an easy start to smart light with the Philips Hue Bluetooth range. Simply screw in your new smart light and control your lighting straight out of the box using the ‘Philips Hue Bluetooth' app. Or try controlling your lights with your voice using Alexa or Google Assistant for hands-free voice control. With our Philips Hue ‘White and Colour Ambiance' range, play with 16 million different colours including warm and cool white light and create the perfect ambiance for any mood. Discover Philips Hue - the latest in smart home lighting!
What's Required – Nothing! This product works out of the box with the free ‘Philips Hue Bluetooth’ app. Simply screw in your new GU10 perfect fit bulb and connect to the Bluetooth app for in room smart lighting control!
Designed for Full Rooms:With a brightness 1100 lumen, these smart LED bulbs provide the perfect amount of light to fill areas of your living room or kitchen, especially when placed in pendant fixtures.
Play with Colour - Choose from 16 million colours including warm to cool white light to create an ambiance that suits any mood. Play with colour to create the perfect ambiance for film nights, parties, bedtime stories, or to just sit back and unwind!
Control Lights With Your Voice - Works with all Echo smart speakers/displays and Google Nest devices for hands-free voice control (Philips Hue Bridge (sold separately) is required for Echo 1st Gen and Echo Dot 1st Gen).
Unlock Your Homes Full Potential – Add a Philips Hue Bridge (sold separately, optional) to your cart and unlock full home control, either when you’re home or away.
Philips Hue - LED light bulb - shape: A60 - E27 - 6.5 W - 16 million colours - 2000-6500 K - white (pack of 2)
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/406181
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
White
Shape
A60
Socket Type
E27
Wattage
6.5 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
570 - 806 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Android compatible, iOS compatible, remote controlled
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
6.5 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
7 kWh
Power Factor
0.8
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
570 - 806 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth, Zigbee
Voice Controlled
Indirect
Body Colour
White
Package
Box
Warranty
2 years
110 mm
Diameter
60 mm
14.6 cm x 7.2 cm x 17.4 cm
-20 °C
45 °C
