The Philips Hue white and color ambiance contains 2 bulbs and a bridge. It can transform your lighting into an extraordinary experience with colored and white light. Sync lights to your music, TV and games for immersive effects.
This Philips Hue starter kit is a great way to make your home smarter, brighter and more colourful. It’s clever enough to let you turn the lights on from anywhere – just grab the app to turn your phone or tablet into a remote control. Easy. If you fancy a gentle wake up call, you can set up a timer schedule to make mornings a little easier on your eyes. Ready for movie night? No worries, the dimmer lets you set the perfect atmosphere in seconds. And with a 25,000-hour lifespan, you won’t have to dash to the shops to buy new bulbs any time soon.
Please note, to get the most out of this light’s features, like controlling it away from home and setting up routines, you’ll need a Philips Bridge (included) and the free Philips Hue app. For everything else, you can control it with the free Philips Hue Bluetooth app. Both apps are compatible with all iOS and Android devices.
                Be creative with colorsPlay with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
                Sync with music and filmsExtend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
                Light up your gamingLift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
                Wake up and go to sleepPhilips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
                Create your ambianceSet the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
- Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - B22 - 9 W - total: 18 W - 16 million colours/warm to cool white light - 2000-6500 K
- Product Type
- Wireless lighting set
- Light Source Type
- 2 x LED light bulb
- Supported Light Bulbs Qty
- 50
- Total Wattage
- 18 W (equivalent 120 W)
- Shape
- A60
- Socket Type
- B22
- Wattage
- 9 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1100 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Product Type
- 50
- Total Wattage
- Android compatible, iOS compatible
Light Source
- Shape
- A60
- Socket Type
- B22
- Wattage
- 9 W
- 60 W
- F
- Energy Consumption per 1000h
- 9 kWh
- Power Factor
- 0.8
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1100 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Upgradable firmware, ZigBee technology, instant full light, voice control, remote controlled, app-controlled, controlled via Bluetooth
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Included Accessories
- Power adapter, network cable, dimmer switch
- Warranty
- 2 years
- 14.6 cm
- 17.6 cm
- 14 cm
- 405 g
- Dimensions & Weight Details
- Light bulb - width: 60 mm x depth: 60 mm x height: 110 mm x diameter: 60 mm - 72 g , Wireless bridge - width: 8.8 cm x depth: 8.8 cm x height: 2.6 cm
- Shipping Dimensions (WxDxH) / Weight
- 760 g
- -10 °C
- 45 °C
