Philips Hue Colour 6.5W A60 E27 Bulbs 3-Pack
Quicklinx: H52YWS00 Mfr#: 929002489603
Type: Light bulb
Compatible With: Alexa, Google Assistant
Hurry, only 2 left in stock!
£108.33 ex VAT
£129.99 inc VAT
With these Philips Hue smart lights, your home will work harder, so you don’t have to. They can be controlled from your phone, so there’ll be no need to climb the stairs if that pesky landing light is still on. And since you can schedule a timer, the lights can turn on or off automatically whenever you need them to. Plus, with 16 million shades to choose from, there’s a colour for every occasion from red hues on Valentine’s to fun greens on St Patricks Day. The brightness can be dimmed as well, which will come in handy for date night. It’s got a 25,000-hour lifespan too, meaning it’ll carry you through the year and long after before you even have to think about replacing it.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (sold separately). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart lighting – control from your phone or tablet
  • White and coloured bulb – choose from 16 million shades
  • Bayonet fitting with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Energy efficient performance
    The Philips Hue light bulb operates at a wattage of 6.5 W, making it a suitable replacement for traditional 60 W bulbs while ensuring lower energy consumption.
  • Wide range of colors
    With 16 million colors available, this light bulb allows for diverse lighting options to match any mood or occasion.
  • Long-lasting durability
    Designed for a lifespan of up to 25,000 hours, the Philips Hue bulb minimizes the need for frequent replacements, providing long-term value.
  • Smart home compatibility
    Compatible with various intelligent assistants including Google Assistant and Alexa, making it easy to control using voice commands.
  • Adaptable for any environment
    This bulb functions effectively within a temperature range of -20°C to 45°C, ensuring reliable operation in various conditions.
Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - E27 - 6.5 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 3)
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/469747
Light Source Type
LED light bulb
Packaged Quantity
3 (specifications are for single item)
Shape
A60
Socket Type
E27
Wattage
6.5 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
800 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50/60 Hz
Packaged Quantity
Light Source
LED light bulb
Shape
A60
Socket Type
E27
Wattage
6.5 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
6.5 kWh
Power Factor
0.8
Colour Temperature
2000-6500 K
Luminous Power
800 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Android compatible, iOS compatible
Power Requirements
AC 220 - 240 V
Frequency Required
50/60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth, Zigbee
Warranty
2 years
60 mm
60 mm
110 mm
Diameter
60 mm
Length
110 mm
72 g
-20 °C
45 °C
Type: Light bulb
Brand: Philips
