With these Philips Hue smart lights, your home will work harder, so you don’t have to. They can be controlled from your phone, so there’ll be no need to climb the stairs if that pesky landing light is still on. And since you can schedule a timer, the lights can turn on or off automatically whenever you need them to. Plus, with 16 million shades to choose from, there’s a colour for every occasion from red hues on Valentine’s to fun greens on St Patricks Day. The brightness can be dimmed as well, which will come in handy for date night. It’s got a 25,000-hour lifespan too, meaning it’ll carry you through the year and long after before you even have to think about replacing it.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (sold separately). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
- Smart lighting – control from your phone or tablet
- White and coloured bulb – choose from 16 million shades
- Bayonet fitting with 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Dim the brightness to match your mood
                Energy efficient performanceThe Philips Hue light bulb operates at a wattage of 6.5 W, making it a suitable replacement for traditional 60 W bulbs while ensuring lower energy consumption.
                Wide range of colorsWith 16 million colors available, this light bulb allows for diverse lighting options to match any mood or occasion.
                Long-lasting durabilityDesigned for a lifespan of up to 25,000 hours, the Philips Hue bulb minimizes the need for frequent replacements, providing long-term value.
                Smart home compatibilityCompatible with various intelligent assistants including Google Assistant and Alexa, making it easy to control using voice commands.
                Adaptable for any environmentThis bulb functions effectively within a temperature range of -20°C to 45°C, ensuring reliable operation in various conditions.
- Philips Hue White and Color Ambiance - LED light bulb - shape: A60 - E27 - 6.5 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 3)
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/469747
- Light Source Type
- LED light bulb
- Packaged Quantity
- 3 (specifications are for single item)
- Shape
- A60
- Socket Type
- E27
- Wattage
- 6.5 W
- Wattage Equivalent
- 60 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 800 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
Light Source
- LED light bulb
- Shape
- A60
- Socket Type
- E27
- Wattage
- 6.5 W
- 60 W
- F
- Energy Consumption per 1000h
- 6.5 kWh
- Power Factor
- 0.8
- 2000-6500 K
- Luminous Power
- 800 lumens
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Android compatible, iOS compatible
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Bluetooth, Zigbee
- Warranty
- 2 years
- 60 mm
- 60 mm
- 110 mm
- Diameter
- 60 mm
- Length
- 110 mm
- 72 g
- -20 °C
- 45 °C
