Offering millions of shades of white and coloured light, this GU10 smart LED bulb instantly sets the mood in any room of your home.
Paint with light
Play with light and choose from 16 million colors in the Hue app to match the light to your mood. Use a favorite photo and re-live that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger. -
Create a personalized experience with colorful smart light
Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. -
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs -
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Control lights with your voice
Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
- Philips Hue White and color - LED spot light bulb - 5.7 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 6)
- Light Source Type
- Packaged Quantity
- 6 (specifications are for single item)
- Wattage
- 5.7 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Intelligent Assistant
- Alexa, Google Assistant - indirect
- Platform
- Nest, Echo
- Communications Technology
- Bluetooth
- Packaged Quantity
Light Source
- Wattage
- 5.7 W
- G
- Energy Consumption per 1000h
- 6 kWh
- 2000-6500 K
- Luminous Power
- 350 lumens
- Dimmable
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Nest, Echo
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Warranty
- 2 years
- Diameter
- 50 mm
- Length
- 58 mm
- 50 g
