Instantly set the mood in any room of your home with these two GU10 bulbs, which offer millions of shades of white and coloured light and fit into most standard spotlights.
Play with light and choose from 16 million colours in the Hue app to match the light to your mood. Use a favourite photo and re-live that special moment with splashes of light. Save your favourite light settings and recall them whenever you want with the tap of a finger.
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
Control up to 10 lights at once with the Bluetooth app
With Hue's Bluetooth app, you can control smart lights within a room. Add up to 10 smart lights and control them with ease from your mobile device. -
Control the lights with your voice
Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Amazon Echo or Google Nest device. Through simple voice commands, you can control just one lamp or multiple lights in a room. -
Create a personalized lighting experience with colorful and smart solutions
Transform your home with over 16 million colors and create the right ambiance for any occasion in a snap. At the touch of a button, immerse yourself in a festive atmosphere, turn your living room into a movie theater, enhance your decor with color, and more. -
Get the perfect light recipes for your daily activities
Simplify your day and make it more enjoyable with four light recipes already programmed and prepared especially for your daily activities: Energy, Concentration, Reading, and Relaxation. The cool-toned scenes, Energy and Concentration, help you get through the morning and not get distracted, while the warmer scenes, Reading and Relaxation, encourage good reading and allow you to calm your mind. -
Set the right mood with warm or cool white lights
These bulbs and lamps offer different shades of warm and cool light. With full dimming from bright to soft, you can choose the perfect light colors to suit your daily needs.
- Philips Hue - LED spot light bulb - GU10 - 4.3 W - 16 million colours/warm to cool white light - 2000-6500 K (pack of 3)
- Light Source Type
- Packaged Quantity
- 3 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 4.3 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Intelligent Assistant
- Cortana, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- Socket Type
- GU10
- Wattage
- 4.3 W
- G
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.8
- 2000-6500 K
- Luminous Power
- 350 lumens
- Dimmable
- Lifetime
- 15000 hours
- Upgradable firmware, ZigBee technology, instant full light, Android compatible, iOS compatible, voice control, app-controlled
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 5 Watt
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- 5 cm
- 5 cm
- 5.8 cm
- Diameter
- 50 mm
- Length
- 58 mm
- 51 g
- Shipping Dimensions (WxDxH) / Weight
- 7.2 cm x 14.6 cm x 17.4 cm / 214 g
- -20 °C
- 45 °C
