Philips Hue Centura Recessed Spotlight - Aluminium 3-Pack
Quicklinx: GVP1WS00 Mfr#: 929003045301
Type: Recessed spot light
Compatible With: Alexa, Google Assistant
Colours:
£114.78 ex VAT
£137.73 inc VAT
Hue Centura offers the perfect splash of ambiance for any occasion. Ideal for your living room and bedroom. Control via Bluetooth to instantly set light scenes in one room or pair with a Hue Bridge to unlock the full suite of features.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Philips Hue White and Color Ambiance Centura - recessed spot light - LED spot light bulb - GU10 - 5.7 W - 16 million colours/warm white to cold white light - 2000-6500 K - aluminium (pack of 3)
Recessed spot light
Recommended For
Kitchen, living room, bedroom, study room, home office
Light Source Type
LED spot light bulb
Packaged Quantity
3 (specifications are for single item)
Supported Light Bulbs Qty
1
Dimmer
Aluminium
Socket Type
GU10
Wattage
5.7 W
Energy Efficiency Class
G
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
350 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue
Communications Technology
Bluetooth
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Recessed spot light
Recommended For
1
Dimmer
Double insulated, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, voice control
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
5.7 W
G
Energy Consumption per 1000h
6 kWh
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
350 lumens
Lifetime
15000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth
Product Material
Synthetics
Body Colour
Aluminium
Package
Box
IP20
Warranty
2 years
9 cm
9 cm
10 cm
Diameter
9 cm
198 g
Dimensions & Weight Details
Hole cut-out diameter: 7 cm
21.9 cm x 10 cm x 20.9 cm / 856 g
Brand: Philips
