Philips Hue Bridge
Philips Hue Bridge
Quicklinx: GLVXWS00 Mfr#: 929001180640
£41.66 ex VAT
£49.99 inc VAT
Get started with Philips Hue and control your lights from your smart phone or tablet, or even with your voice. The Philips Hue Bridge is the heart of the system. It unlocks endless possibilities through the Philips Hue app.
The heart of your Philips Hue system
The Philips Hue bridge is all you need to set up your personal Philips Hue system. This is actually the brain of the operation that enables you to control all of your Philips Hue products via the Philips Hue app. Once you have installed the Philips Hue bridge and downloaded the Philips Hue app on your smart device, you can set your imagination free and build your very own system
Add up to 50 Philips Hue lights
Select the Philips Hue lights of your choice and connect them to your Philips Hue bridge. The bridge is powerful enough to handle up to 50 lights, so Hue-ify your whole house
Extend with Philips Hue accessories
In the Philips Hue system, you can also connect up to 12 accessories to enhance your connected lighting experience even further
Smart control, home and away
With the Philips Hue iOS and Android apps you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late.
Control with your voice
Philips Hue works with Amazon Alexa, Apple HomeKit and Google Home, powered by the Google Assistant, to allow you to control your lights with your voice. Turn your lights on and off. Dim to the desired brightness for a perfect ambiance. Even recall pre-set scenes, change colors and more - all without lifting a finger.
ZigBee technology
Philips Hue is based on ZigBee, a low-power and reliable technology to control your lights. New features and improvements are continuously added to the system. Updates to both software and firmware are done wirelessly and seamlessly, directly to your Philips Hue product
  • The Hue Bridge
    The Hue Bridge is an essential component to a personal Philips Hue smart lighting system. It is the brains of the operation, communicating with both your smart light bulbs and the Hue app to ensure that everything works together. It also enables smart home automation features like scheduling routines and timers.
  • Add smart switches and sensors
    Enhance your Hue smart lighting system with various accessories, including smart dimmer switches and motion sensors.
  • Away-from-home control
    Connect your smart lights to the Hue Bridge and download the Hue app to ensure that your home is well lit no matter where you are. Set light routines in the app to turn your lights on at a certain time, mimicking your presence to give you peace of mind.
  • Connect up to 50 smart lights
    The Hue Bridge allows you to connect up to 50 lights, so you can outfit your entire home - inside and out - and control them all within the app.
Philips Hue Bridge - central controller - ZigBee
Central controller
Functions
Light control
Power Source
Power adapter
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Cortana, Alexa ready, Google Assistant ready - indirect
Max Supported Devices
50
Wireless, wired - ZigBee - Ethernet
Frequency Band
2400 - 2483.5 Mhz
Supported Host Device OS
iOS, Android
United Kingdom
9.09 cm x 9.09 cm x 2.6 cm
Central controller
Functions
Light control
Power Source
Power adapter
50
Wireless, wired - Ethernet, ZigBee
Frequency Band
2400 - 2483.5 Mhz
Android 8.0 (Oreo) or later, iOS 13 or later
Interfaces Details
LAN
Wall mountable
Platform
Apple HomeKit
Voice Controlled
Indirect
Power adapter, network cable
United Kingdom
AC 100-240 V
Rated Current
600 mA
Warranty
9.09 cm
9.09 cm
2.6 cm
Shipping Width
14.6 cm
Shipping Depth
7.2 cm
Shipping Height
17.4 cm
Shipping Weight
313 g
0 - 80% (non-condensing)
Type: Bridge
Compatible With: Cortana
Compatible With: Google Assistant ready
Compatible With: Alexa ready
Brand: Philips
