Philips Hue Bloom - White
Quicklinx: GSB2WS00 Mfr#: 929002375901
Type: Desk lamp
Compatible With: Siri, IFTTT, Alexa, Google Assistant
£58.33 ex VAT
£69.99 inc VAT
Effortlessly set the mood in any room of your home with the unconventional, compact Philips Hue Bloom. Simply plug in to a plug socket and use the Bloom to cast colorful light as a standalone lamp or add it to your existing Hue system as an accent light.
A plug-and-play accent lamp
The Philips Hue Bloom is a small, versatile smart lamp that casts light in any of millions of colors. The Bloom's easy plug-and-play design lets you place the lamp anywhere: place it on a table to wash the walls with beautiful light, set it on your nightstand for a gentle nightlight or position it near your TV to enhance your entertainment with light.
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
Get the perfect light recipes for your daily activities
Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energise, Concentrate, Read and Relax. The two cool-toned scenes, Energise and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
Control with app or voice
Philips Hue works with Amazon Alexa, Siri and the Google Assistant. Simple voice commands let you dim, brighten or change the colour of your lights, whether you want to control a single lamp or all lights in your home. Voice control requires a Philips Hue Bridge and a compatible partner device.
Create a personalised experience with colourful smart light
Transform your home with over 16 million colours, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theatre, enhance your home decor with colour accents, and much more.
Unlock the full suite of smart lighting features with the Bridge
The Bridge unlocks the features that make smart lighting truly smart - away-from-home control, voice control, automated lighting and much more. Add a Bridge to your setup to create immersive experiences, tap into technology that's secure and reliable, and more. The Bridge is the key to smart lighting like you've never seen before.
  • A Plug-and-Play accent lamp
    The Philips Hue Bloom is a small, versatile smart lamp that casts light in any of millions of colors. The Bloom's easy Plug-and-Play design lets you place the lamp anywhere: place it on a table to wash the walls with beautiful light, set it on your nightstand for a gentle nightlight or position it near your TV to enhance your entertainment with light.
  • Control up to 10 lights with the Bluetooth app
  • Control lights with your voice
    Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
  • Set the right mood with warm to cool white light
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
Philips Hue Bloom - desk lamp - LED - 7.1 W - 16 million colours - 2000-6500 K - white
Desk lamp
Light Source Type
LED
White
Wattage
7.1 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue, Nest
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Desk lamp
Remote controlled, ZigBee Light Link
Light Source
LED
Built-in LED Lamp
Wattage
7.1 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Lifetime
25000 hours
Colour changing LED, ZigBee technology
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue, Nest
Bluetooth, Zigbee
Voice Controlled
Indirect
Product Material
Metal, plastic
Body Colour
White
UK power plug
Package
Box
Plug and Play, IP20
Warranty
2 years
12.9 cm
10.1 cm
Length
12.6 cm
452 g
Type: Desk lamp
Compatible With: IFTTT
Compatible With: Alexa
Brand: Philips
