Philips Hue Bloom - Black
Quicklinx: GSB3WS00 Mfr#: 929002376001
Type: Decoration lamp
Compatible With: Alexa, Google Assistant
Hurry, only 3 left in stock!
£58.33 ex VAT
£69.99 inc VAT
Add a Philips Hue Iris to your system. A stylish lamp that sits on your desk, your shelf or the floor and washes your walls with beautiful colored light.
  • Plug and Play
    Philips Hue Bloom is designed to create indirect ambient lighting and is a perfect way to highlight specific furniture or architectural features in your home. And because it is a plug-based product, you can easily move it around and place it where a power socket is available. Put it on your TV cabinet, your desk or just below your favorite painting. Place it either in or out of sight, and the award-winning design will blend seamlessly with your interior.
  • Highlight with color
    Choose from 16 million colors. Add accents to your home, light a space with a splash of color or wash your walls with stunning shades. Dim down the intensity and blend soft color tones for smooth light effects.
  • Sync lights with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party APPs and discover the amazing things you can do with Philips Hue.
  • Smart control, home and away
    With the Philips Hue iOS and Android APPs, you can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left home, and switch them on if you are working late.
  • Set timers for your convenience
    Philips Hue can make it seem like you're at home when you're not, using the schedule function in the Philips Hue APP. Set the lights to come on at a pre-set time, so the lights are on when you arrive home. You can even set rooms to light up at different times. And of course, you can let the lights turn off gradually in the night, so you never have to worry whether you've left any lights on.
  • Installation-free dimming
    Experience guaranteed smooth dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for wires, an electrician or installation
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue APP, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
  • Requires a Philips Hue bridge
    Connect your Philips Hue lights with the bridge to control your lights from your smartphone or tablet via the Philips Hue APP.
Philips Hue White and Color Ambiance Bloom - decoration lamp - LED - 7.1 W - 16 million colours - 2000-6500 K - black
Decoration lamp
Light Source Type
LED
Wattage
7.1 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Decoration lamp
Protection class III, ZigBee Light Link, diffused light effect
Light Source
LED
Built-in LED Lamp
Wattage
7.1 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
500 lumens
Lifetime
25000 hours
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Bluetooth
Voice Controlled
Indirect
Product Material
Metal, plastic
Body Colour
UK power plug
Package
Box
IP20
Warranty
2 years
129 mm
126 mm
101 mm
452 g
218 mm x 111 mm x 227 mm / 760 g
Brand: Philips
