Philips Hue Belle Lamp
Quicklinx: H4VLWS00 Mfr#: 929003128501
Type: Table lamp
Compatible With: Alexa
£99.99 ex VAT
£119.98 inc VAT
Brighten up your day with this Philips Hue smart table lamp.
Forget faffing with switches – control it from wherever you’re sat using your smartphone or tablet. And with a whopping 16 million shades to choose from, it’s safe to say there’s colours for every occasion.
There’s no need to worry about changing that bulb every week either, as its massive 25,000-hour lifespan LED bulb will keep things shining on and on…and on.
Won’t be back ‘til late? No worries. Just schedule your light to switch on automatically when it suits you best. Plus, you can dim the lights to suit your mood too, whether that’s nice and vibrant or something a bit more subtle. Watt a great idea.
Please note, to get the most out of this light’s features, like controlling it away from home and setting up routines, you’ll need a Philips Bridge (sold separately) and the free Philips Hue app. For everything else, you can control it with the free Philips Hue Bluetooth app. Both apps are compatible with all iOS and Android devices.
  • Smart table lamp – control from your phone or tablet
  • White and coloured bulb – choose from 16 million shades
  • LED light with 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Carry light anywhere
    Bring the Go portable table lamp where you need light most, such as inside to read or outside to illuminate a dinner party.
  • Control your way
    Use the on-product control button, the Hue app, your voice or smart accessories to control your lamp.
  • Dynamic lighting effects
    Use the on-product button to cycle through special light effects, such as a candlelight glow with Cozy candle.
  • Smart battery management
    Press and hold the button to put it in standby mode, saving battery life. If the lamp is off its charging base for longer than 12 hours, it'll go into battery save mode - wake it up by long pressing the button again.
Philips Hue Go - table lamp - LED - hue white and colour ambiance - black, dark grey handle
Table lamp
Light Source Type
LED
Dimmer
Black, dark grey handle
Energy Efficiency Class
G
Colour of Illumination
Hue white and colour ambiance
Luminous Power
530 lumens
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Table lamp
Dimmer
Waterproof
Indoor/outdoor usage, portable, on/off switch
Light Source
LED
Built-in LED Lamp
G
Colour Rendering Index
80
Luminous Power
530 lumens
Lifetime
20000 hours
Power Requirements
AC 220 - 240 V
Rechargeable
Run Time
48 hrs
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Bluetooth, Zigbee
Product Material
Metal, silicone handle
Body Colour
Charging base
Package
Box
IP54, IP20
Warranty
2 years / 30 days return
14.2 cm
14.2 cm
35 cm
1.2777 kg
20.9 cm x 21.9 cm x 38.8 cm / 1.821 kg
Type: Table lamp
Brand: Philips
