Featuring a unique aluminum design, the Being ceiling light installs flat against your ceiling to provide a seamless apperance. Connect it to the Hue Bridge and control it your way.
Get in the mood
Use over 50,000 shades of warm to cool white light to put you in the mood to work, play, or relax - no matter what time of day it is. Start your morning off on the right foot with cool, energizing bright white light, or settle down for the night with golden tones. -
Smart lighting for daily tasks
Make your day easier with four preset light scenes that have been handcrafted for your daily tasks. Two cool-toned scenes, Energize and Concentrate, help you get going in the morning and keep your focus, while the warmer scenes of Read and Relax help you enjoy a good book and a rested mind. -
Control lights away from home
The Hue app gives you complete control over your lights, even if you're not home. Switch your lights off and on remotely using just the app to ensure your home is always lit the way you want it. -
Wake up and sleep
Set your lights to slowly brighten in the morning at a preset time to mimic sunrise and help you start your day feeling calm and refreshed. In the evening, the relaxing warm white lights will help you unwind, relax and prepare your body for a good night's sleep. -
Control with your voice
When connected to the Hue Bridge, you can pair your lights with Alexa, Apple HomeKit, and the Google Assistant and control your lights using just your voice. Simple voice commands let you turn your lights on and off, dim or brighten your lights, and even set a light scene. -
Connect to the Hue Bridge
This product requires a connection to the Hue Bridge to unlock the full smart control and features. Control your lights using the Philips Hue app, set timers, routines, add or remove lights and more.
- Philips Hue White ambiance Being - pendant lamp - LED - 25 W - warm white to cool natural light - 2200-6500 K - aluminium
- Product Type
- Pendant lamp
- Recommended For
- Office
- Light Source Type
- LED
- Light Cover Type
- Diffuser
- Dimmer
- Aluminium
- Wattage
- 25 W
- Wattage Equivalent
- 204 W
- Colour of Illumination
- Warm white to cool natural light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 2900 lumens
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Google Home, Hue
- Communications Technology
- Bluetooth
- Frequency Required
- 50 - 60 Hz
- Light Source Voltage
- 24 V
- Product Type
- Pendant lamp
- Recommended For
- Office
- Light Cover Type
- Diffuser
- Dimmer
- Protection class I, Android compatible, iOS compatible, remote controlled, controlled via Bluetooth, app-controlled, EyeComfort, power on/off timer
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 25 W
- 204 W
- 2200-6500 K
- Luminous Power
- 2900 lumens
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
- 24 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Product Material
- Metal, plastic
- Body Colour
- Aluminium
- Included Accessories
- Dimmer switch, CR2032 battery
- IP20
- Warranty
- 2 years / 30 days return
- 48.2 cm
- 48.2 cm
- Min: 8 cm - max: 158 cm
- 3.61 kg
- Shipping Dimensions (WxDxH) / Weight
- 50 cm x 15 cm x 50 cm / 4.6 kg
