Philips Hue B22 Starter Set
Quicklinx: GQV4WS00 Mfr#: 929002468906
£99.99 ex VAT
£119.98 inc VAT
Get in the mood with warm to cool white smart lights
Use over 50,000 shades of warm to cool white light to put you in the mood to work, play, or relax — no matter what time of day it is. Start your morning off on the right foot with cool, energising bright white light, or settle down for the night with golden tones.
Play with smart colour lights
There’s no limit with Philips Hue: with over 16 million colours, you can transform your home into the perfect party venue, bring a bedtime story to life and much more. Use preset, coloured light scenes to evoke the feeling of summer any time you'd like, or use your own photo to relive a special memory.
Away-from-home smart light control
The Philips Hue app gives you complete control over your lights, even if you're not at home. Switch your lights off and on remotely using just the app to ensure your home is always lit the way you want it.
Sync films, TV programmes, music, and games to smart lights
Bring your entertainment to new heights by syncing the action on the screen or the beat of your music to your smart lights.* Choose the way you'd like to sync your lights to your film, music (including with our Spotify integration!), TV programme or game and watch as the colour-capable lights in your Entertainment area react. *Hue Bridge required
Wireless control with included dimmer switch
With the battery-powered dimmer switch, you can control up to 10 smart lights simultaneously. The switch – which can be removed from its wall mount and used as a remote control – allows you to dim and brighten your lights or cycle through four preset light recipes
  • Remote control
    You can control your lights remotely, wherever you are. Check if you have forgotten to switch off your lights when you leave home or switch them on when you are working late. With geofencing technology, your lights can also welcome you home or turn off automatically when you leave your home. This is a smart and useful way to simplify your life and give you complete peace of mind.
  • Convenient dimming
    Experience guaranteed easy dimming with Philips Hue. Not too bright. Not too dark. Just right. No need for cables, electricians or installation.
  • Program your light
    Using the programming function in the Philips Hue app, your Philips Hue lights can appear to be at home. Set a switch-on time so that the light is on when you get home. You can even control the lighting in individual rooms at different times. And of course, you can gradually switch the lights off in the evening so you never have to wonder if you left the lights on again.
Philips Hue Starter Kit - wireless lighting set - LED light bulb x 2 - shape: A60 - B22 - 9 W - total: 18 W - 16 million colours/warm to cool white light - 2000-6500 K
Wireless lighting set
Light Source Type
2 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
18 W (equivalent 120 W)
Dimmer
Shape
A60
Socket Type
B22
Wattage
9 W
Wattage Equivalent
60 W
Energy Efficiency Class
F
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
1100 lumens
Intelligent Assistant
Siri, Cortana, Google Assistant, Alexa
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
Dimmer
Light Source
2 x LED light bulb
Shape
A60
Socket Type
B22
Wattage
9 W
Wattage Equivalent
60 W
F
Energy Consumption per 1000h
9 kWh
Power Factor
0.5
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
1100 lumens
Lifetime
25000 hours
Switch Cycles
50000
Instant full light, app-controlled
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Power adapter, wireless bridge, network cable, dimmer switch
Package
Box
IEEE 802.15.4
Warranty
2 years
Dimensions & Weight Details
Wireless bridge height: 26 mm , Light bulb height: 110 mm x diameter: 60 mm - 76 g , Dimmer switch - width: 35 mm x depth: 11 cm x height: 9.2 cm - 37 g , Wall plate - width: 70 mm x depth: 14 mm x height: 115 mm
-20 °C
45 °C
Type: Wireless lighting set
Compatible With: Siri
Compatible With: Cortana
Compatible With: Alexa
Brand: Philips
