The Appear wall light offers 16 million colours of subtle yet powerful light, by directing its beams both up and down, creating a sharp, directed triangle of light against the wall of your front or back patio.
16 million colors
Personalize your home for your perfect ambience with over 16 million colors. -
Unique architectural light shapes
Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface. -
High-quality inox and superior synthetics
The products are specifically made for outdoor use, utilizing high-quality materials to ensure optimal performance in outdoor conditions. Additionally, they are designed with the smart use of materials to optimize radio frequency. -
Come home to a house filled with light
Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically. -
Unwind with warm to cool white light
Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. -
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
- Philips Hue Appear - wall lamp - LED x 2 - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - inox (pack of 2)
- Product Type
- Wall lamp
- Recommended For
- Balcony, patio, porch
- Light Source Type
- 2 x LED
- Packaged Quantity
- 2 (specifications are for single item)
- Dimmer
- Inox
- Wattage
- 8 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 710 - 1180 lumens
- Intelligent Assistant
- Google Assistant, Alexa, Apple HomeKit - indirect
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Wall lamp
- Recommended For
- Dimmer
- Weatherproof, outdoor usage, protection class I
Light Source
- 2 x LED
- Built-in LED Lamp
- Wattage
- 8 W
- G
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 710 - 1180 lumens
- Lifetime
- 25000 hours
- Light scheduling, app-controlled, weatherproof
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Compatible Application
- Philips Hue App
- Voice Controlled
- Indirect
- Product Material
- Stainless steel body
- Body Colour
- Inox
- IP44
- Warranty
- 2 years
- 8.4 cm
- 11.7 cm
- 24 cm
