Philips hue Appear Wall Lantern offers 16 million colors to enhance the beauty of your patio or pathway, as well as all shades of white to brighten your yard or enhance security. Easily connect to your existing hue bridge to get all the smart features including away from home control, geofencing, scheduling, or linking to the Philips hue Outdoor Motion Sensor. The Appear lantern is fully weatherproof.
Weather-proof (IP44)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction, making it ideal for general outdoor use. -
High-quality aluminum and superior synthetics
The products are specifically designed for outdoor use, employing high-quality materials to ensure optimal performance in outdoor conditions, as well as smart material usage to optimize radio frequency. -
Unwind with warm to cool white light
Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year. -
Decorate for the holidays with light
Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween. -
Come home to a house filled with light
Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically. -
Unique architectural light shapes
Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
- Philips Hue White and Color Ambiance Appear - wall lamp - LED - 8 W - 16 million colours - 2000-6500 K - black
- Product Type
- Wall lamp
- Light Source Type
- LED
- Supported Light Bulbs Qty
- 2
- Black
- Wattage
- 8 W
- Wattage Equivalent
- 49 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1200 lumens
- Dimmable
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Wall lamp
- 2
- Weatherproof, outdoor usage, splashproof, protection class I, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 8 W
- 49 W
- 2000-6500 K
- Luminous Power
- 1200 lumens
- Dimmable
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Product Material
- Metal, aluminium
- Body Colour
- Black
- Package
- Box
- IP44
- Warranty
- 2 years
- 84 mm
- 117 mm
- 240 mm
- 995 g
- Shipping Dimensions (WxDxH) / Weight
- 130 mm x 105 mm x 295 mm / 1.12 kg
