Philips Hue Appear Wall Lantern - Black
Quicklinx: GVY4WS00 Mfr#: 915005842801
Type: Wall lamp
Compatible With: Alexa
11 In Stock
£99.99 ex VAT
£119.98 inc VAT
Philips hue Appear Wall Lantern offers 16 million colors to enhance the beauty of your patio or pathway, as well as all shades of white to brighten your yard or enhance security. Easily connect to your existing hue bridge to get all the smart features including away from home control, geofencing, scheduling, or linking to the Philips hue Outdoor Motion Sensor. The Appear lantern is fully weatherproof.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction, making it ideal for general outdoor use.
  • High-quality aluminum and superior synthetics
    The products are specifically designed for outdoor use, employing high-quality materials to ensure optimal performance in outdoor conditions, as well as smart material usage to optimize radio frequency.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Decorate for the holidays with light
    Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
  • Unique architectural light shapes
    Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
Philips Hue White and Color Ambiance Appear - wall lamp - LED - 8 W - 16 million colours - 2000-6500 K - black
Wall lamp
Light Source Type
LED
Supported Light Bulbs Qty
2
Wattage
8 W
Wattage Equivalent
49 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Dimmable
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Wall lamp
2
Weatherproof, outdoor usage, splashproof, protection class I, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
49 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Metal, aluminium
Body Colour
Package
Box
IP44
Warranty
2 years
84 mm
117 mm
240 mm
995 g
130 mm x 105 mm x 295 mm / 1.12 kg
Type: Wall lamp
Brand: Philips
