Philips Hue Appear Outdoor Wall Light Twin Pack
Quicklinx: GQSKWS00 Mfr#: 919213000344
Type: Outdoor lighting
Compatible With: Alexa, Google Assistant, Siri, IFTTT
15 In Stock
£224.98 ex VAT
£269.97 inc VAT
The Appear Wall Lantern offers 16 million colours to enhance the beauty of your home, as well as all 15 thousand shades of white to brighten your yard or enhance security. Designed to beam a direct, triangular-shaped wash of light both up and down your wall, the Appear outdoor light from Philips is a smart choice for the front porch. With an integrated LED and Hue technology, you can choose between bright, colourful light or warm white light to illuminate your outdoor space. It's made from high-quality aluminium and synthetics that have been performance-tested in outdoor conditions.
Colourful and smart lighting
Highlight objects, trees or pathways and make your outdoors a stand-out space. This light is equipped with 16 million colours and all shades of white light so you can create the exact lighting effect you want. Use your lantern to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for Spring or even an eerie purple glow to create the most haunted house on the street this Halloween.
Designed for the outdoors
Specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
*Requires Philips Hue Bridge
A Philips Hue Bridge is required for smart lighting control and available to purchase separately. Once connected, you'll experience the full potential of this smart light and can use the Philips Hue app to control it from your smart phone or tablet. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple HomeKit, and the Google Assistant to allow you to control your lights with your voice.
  • 16 million colors
    Create the perfect ambience for you and your home with 16 million colors.
  • Unique architectural light shapes
    Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
  • High-quality aluminum and superior synthetics
    The products are specifically made for outdoor use, utilizing high-quality materials to ensure optimal performance in outdoor conditions. Additionally, they are designed with the smart use of materials to optimize radio frequency.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
Philips Hue Appear - wall lamp - LED light bulb - 8 W - 16 million colours/tunable white - 2000-6500 K - black (pack of 2)
Wall lamp
Recommended For
Garden
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Supported Light Bulbs Qty
1
Dimmer
Wattage
8 W
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
710 - 1180 lumens
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Wall lamp
Recommended For
Garden
1
Dimmer
Weatherproof, outdoor usage
Light Source
LED light bulb
Wattage
8 W
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
710 - 1180 lumens
Lifetime
25000 hours
Light scheduling, app-controlled, weatherproof
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Product Material
Metal
Body Colour
IP44
Warranty
2 years
8.4 cm
11.7 cm
24 cm
13.8 cm x 15 cm x 21.6 cm / 750 g
Compatible With: Siri
Compatible With: IFTTT
Brand: Philips
