Philips Hue Appear Outdoor Wall Lantern
Quicklinx: GP6BWS00 Mfr#: 915005976301
Type: Outdoor lighting
Compatible With: IFTTT, Siri, Alexa, Google Assistant
£108.33 ex VAT
£129.99 inc VAT
The Appear Wall Lantern offers 16 million colours to enhance the beauty of your home, as well as all 15 thousand shades of white to brighten your yard or enhance security. Designed to beam a direct, triangular-shaped wash of light both up and down your wall, the Appear outdoor light from Philips is a smart choice for the front porch. With an integrated LED and Hue technology, you can choose between bright, colourful light or warm white light to illuminate your outdoor space. It's made from high-quality aluminium and synthetics that have been performance-tested in outdoor conditions.
Colourful and smart lighting
Highlight objects, trees or pathways and make your outdoors a stand-out space. This light is equipped with 16 million colours and all shades of white light so you can create the exact lighting effect you want. Use your lantern to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for Spring or even an eerie purple glow to create the most haunted house on the street this Halloween.
Designed for the outdoors
Specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
*Requires Philips Hue Bridge
A Philips Hue Bridge is required for smart lighting control and available to purchase separately. Once connected, you'll experience the full potential of this smart light and can use the Philips Hue app to control it from your smart phone or tablet. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple HomeKit, and the Google Assistant to allow you to control your lights with your voice.
Material - stainless steel
Philips Hue White and Color Ambiance Appear - wall lamp - LED x 2 - 8 W - total: 16 W - 16 million colours - 2000-6500 K - inox
Wall lamp
Light Source Type
2 x LED
Total Wattage
16 W
Inox
Wattage
8 W
Wattage Equivalent
49 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Wall lamp
Total Wattage
16 W
Outdoor usage
Light Source
2 x LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
49 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1200 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Voice Controlled
Indirect
Product Material
Stainless steel
Body Colour
Inox
IP44
Warranty
2 years
8.4 cm
11.7 cm
24 cm
1.123 kg
13 cm x 10.5 cm x 29.5 cm / 1.288 kg
Compatible With: Siri
Compatible With: Alexa
Brand: Philips
