Wash large expanses of your outdoor spaces, such as fences, walls and hedges, with white and color light. Part of the LowVolt system, the Amarant linear spotlight connects to a Philips Hue power supply unit and can even be connected to one another, creating a continuous wall of light.
Connect multiple lights
Thanks to its LowVolt design, the Amarant connects to a single power supply unit. Once you have one set up, you can connect multiple linear spotlights to the first, creating a daisy chain of lights. -
A wash of colorful light
The built-in metal shield directs light upwards and out, creating an even spread of light across large surfaces - and eliminating harsh glare. The Amarant is best for large walls, fences or hedges that span a large length of your garden. -
Easy to install and extend
Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs. -
Weather-proof (IP65)
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP65: this means that it is protected against low-pressure jets of water. It is a higher level of protection than IP44 and commonly used when luminaires are close to the ground or require higher protection due to certain outdoor conditions. -
Requires a Philips Hue bridge
Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities. -
Control it your way
Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice. -
Paint your outdoors with 16 million colors
With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger. -
Special light for special occasions
Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween.
- Philips Hue White and Color Ambiance Amarant - light bar - LED - 20 W - 16 million colours - 2000-6500 K - black
- Product Type
- Light bar
- Light Source Type
- LED
- Black
- Wattage
- 20 W
- Wattage Equivalent
- 104 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1400 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Hue
- Product Type
- Light bar
- Outdoor usage, protection class III, LowVolt, built-in metal shield
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 20 W
- 104 W
- 2000-6500 K
- Luminous Power
- 1400 lumens
- Lifetime
- 25000 hours
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Voice Controlled
- Indirect
- Product Material
- Metal, synthetics
- Body Colour
- Black
- IP65
- Warranty
- 2 years
- 79.5 cm
- 6.8 cm
- 5 cm
- 1.68 kg
- Shipping Dimensions (WxDxH) / Weight
- 12.6 cm x 7.1 cm x 88 cm / 1.965 kg
