Extend your evenings with Philips Hue outdoor lighting. Set the right ambiance on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
Energy efficient lighting
The Philips Hue Lily features an LED light source with an energy consumption of only 8 kWh per 1000 hours, allowing for significant energy savings while providing bright and effective lighting. -
Versatile installation
Designed with a tilting base and a ground spike, this light can be easily adjusted and positioned to highlight features of any garden or outdoor area. -
Weather resistant design
Compliant with IP65 standards, this garden spot light is both waterproof and dustproof, making it suitable for various weather conditions. -
Extensive color range
Experience personalized lighting with 16 million color options and a color temperature range of 2000-6500 K, perfect for setting the mood in any outdoor space. -
Smart home integration
Compatible with the Philips Hue Bridge, this light can be easily integrated into a smart home system, allowing control via the Philips Hue app or voice commands through various intelligent assistants.
- Philips Hue Lily Base and Extension Kit - garden spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 4)
- Product Type
- Garden spot light
- Recommended For
- Patio
- Light Source Type
- LED
- Packaged Quantity
- 4 (specifications are for single item)
- Style
- Functional
- Cable Length
- 0.5 m
- Black
- Wattage
- 8 W
- Wattage Equivalent
- 40 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 350 - 1770 lumens
- Dimmable
- Intelligent Assistant
- Alexa, Google Assistant, Siri - indirect
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Garden spot light
- Recommended For
- Patio
- Style
- Functional
- Position Adjustments
- Tilting base
- Cable Length
- 0.5 m
- Waterproof
- Outdoor usage, LowVolt system, remote controlled, voice control, app-controlled, interconnectable, weatherproof, ground spike, wireless dimmer switch, dustproof, waterproof, double insulated, power on/off timer, non-replaceable light bulb
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 8 W
- 40 W
- E
- Energy Consumption per 1000h
- 8 kWh
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 350 - 1770 lumens
- Dimmable
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Voice Controlled
- Indirect
- Product Material
- Aluminium
- Body Colour
- Black
- Included Accessories
- Power supply, ground spike, power plug
- Package
- Box
- IP65
- Warranty
- 2 years
- 7.112 cm
- 19.304 cm
- Length
- 8.382 cm
- 3.18 kg
- Dimensions & Weight Details
- Ground spike height: 17.27 cm
- Shipping Dimensions (WxDxH) / Weight
- 24 cm x 31.5 cm x 22.5 cm / 4.45 kg
- -20 °C
- 40 °C
