Philips Hue 4.2W GU10 Tunable Smart LED 3-Pack Bulbs
Quicklinx: J1CZWS00 Mfr#: 929003666703
Type: Light bulb
Compatible With: Alexa, Google Assistant, Cortana
Hurry, only 1 left in stock!
£49.99 ex VAT
£59.98 inc VAT
The Philips Hue White ambiance light bulb offers versatility with its range of warm to cool white light. Designed for convenience and energy efficiency, this LED spot light bulb provides instant full light at a wattage of only 4.2 W, making it an economical choice for any space. With a lifetime of up to 25,000 hours and the ability to withstand 50,000 switch cycles, this bulb ensures longevity and reliability. Its 400 lumens of luminous power and color rendering index of 90 deliver brightness and clarity, enhancing the ambiance of any room while promoting energy conservation.
This light bulb is IoT-compatible, allowing seamless integration with smart home systems. Featuring communications technologies such as Bluetooth and Zigbee, it connects effortlessly with the Philips Hue Bridge. Enjoy the convenience of voice control via intelligent assistants like Google Assistant, Alexa, and Cortana, making it simple to adjust lighting without lifting a finger. Whether through the Philips Hue App or voice command, this bulb offers accessibility and adaptability to any lighting need.
  • Energy efficient lighting
    With a power consumption of just 4.2 W, this light bulb minimizes energy costs while providing ample illumination.
  • Smart home integration
    Compatible with Philips Hue Bridge and smart assistants for seamless connectivity and control over your lighting environment.
  • Customizable light settings
    Offers a range of color temperatures and brightness levels, allowing users to create the perfect ambiance for any situation.
  • Impressive lifespan
    Built to last up to 25,000 hours, ensuring prolonged use and reduced frequency of replacements.
  • Efficient performance
    Delivers 400 lumens of brightness with a color rendering index of 90, ensuring high-quality light output.
Philips Hue White ambiance - LED spot light bulb - GU10 - 4.2 W - warm to cool white light - 2200-6500 K (pack of 3)
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1805049
Light Source Type
LED spot light bulb
Packaged Quantity
3 (specifications are for single item)
Socket Type
GU10
Wattage
4.2 W
Energy Efficiency Class
E
Colour of Illumination
Warm to cool white light
Colour Temperature
2200-6500 K
Luminous Power
400 lumens
Beam Angle
90 degree(s)
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Hue, Google Home ready
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Packaged Quantity
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
4.2 W
E
Energy Consumption per 1000h
5 kWh
Power Factor
0.5
Colour Temperature
2200-6500 K
Colour Rendering Index
90
Luminous Power
400 lumens
Maximum Beam Candela Power
677 cd
Beam Angle
90 degree(s)
Beam Angle Correspondence
Narrow cone (90°)
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Instant full light
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.25 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Package
Hanging box
Warranty
2 years
5.7 cm
Diameter
5 cm
50 g
7.2 cm x 7.2 cm x 17.4 cm / 190 g
Type: Light bulb
Compatible With: Cortana
Brand: Philips
