The Philips Hue White ambiance light bulb offers versatility with its range of warm to cool white light. Designed for convenience and energy efficiency, this LED spot light bulb provides instant full light at a wattage of only 4.2 W, making it an economical choice for any space. With a lifetime of up to 25,000 hours and the ability to withstand 50,000 switch cycles, this bulb ensures longevity and reliability. Its 400 lumens of luminous power and color rendering index of 90 deliver brightness and clarity, enhancing the ambiance of any room while promoting energy conservation.
This light bulb is IoT-compatible, allowing seamless integration with smart home systems. Featuring communications technologies such as Bluetooth and Zigbee, it connects effortlessly with the Philips Hue Bridge. Enjoy the convenience of voice control via intelligent assistants like Google Assistant, Alexa, and Cortana, making it simple to adjust lighting without lifting a finger. Whether through the Philips Hue App or voice command, this bulb offers accessibility and adaptability to any lighting need.
Energy efficient lighting
With a power consumption of just 4.2 W, this light bulb minimizes energy costs while providing ample illumination. -
Smart home integration
Compatible with Philips Hue Bridge and smart assistants for seamless connectivity and control over your lighting environment. -
Customizable light settings
Offers a range of color temperatures and brightness levels, allowing users to create the perfect ambiance for any situation. -
Impressive lifespan
Built to last up to 25,000 hours, ensuring prolonged use and reduced frequency of replacements. -
Efficient performance
Delivers 400 lumens of brightness with a color rendering index of 90, ensuring high-quality light output.
- Philips Hue White ambiance - LED spot light bulb - GU10 - 4.2 W - warm to cool white light - 2200-6500 K (pack of 3)
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/screen/product/lightsources/1805049
- Light Source Type
- Packaged Quantity
- 3 (specifications are for single item)
- Socket Type
- GU10
- Wattage
- 4.2 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Warm to cool white light
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 400 lumens
- Beam Angle
- 90 degree(s)
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa, Cortana - indirect
- Platform
- Hue, Google Home ready
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Packaged Quantity
Light Source
- Socket Type
- GU10
- Wattage
- 4.2 W
- E
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Colour Rendering Index
- 90
- Luminous Power
- 400 lumens
- Maximum Beam Candela Power
- 677 cd
- Beam Angle
- 90 degree(s)
- Beam Angle Correspondence
- Narrow cone (90°)
- Dimmable
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Instant full light
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Power Consumption Stand by
- 0.25 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- 5.7 cm
- Diameter
- 5 cm
- 50 g
- Shipping Dimensions (WxDxH) / Weight
- 7.2 cm x 7.2 cm x 17.4 cm / 190 g
