The Philips Hue white and color ambiance contains 3 bulbs, a bridge and a switch. It can transform your lighting into an extraordinary experience with colored and white light. Sync lights to your music, TV and games for immersive effects.
                Be creative with colorsPlay with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
                Sync with music and filmsExtend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
                Light up your gamingLift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
                Wake up and go to sleepPhilips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
                Create your ambianceSet the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
- Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED spot light bulb x 3 - GU10 - 4.2 W - multicolour/warm to cool white light - 2000-6500 K
- Product Type
- Wireless lighting set
- Light Source Type
- 3 x LED spot light bulb
- Supported Light Bulbs Qty
- 50
- Dimmer
- Socket Type
- GU10
- Wattage
- 4.2 W
- Energy Efficiency Class
- E
- Colour of Illumination
- Multicolour/warm to cool white light
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 400 lumens
- Intelligent Assistant
- Cortana, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- 50
- Dimmer
- Android compatible, iOS compatible, controlled via Bluetooth, app-controlled, voice control, 2400 - 2483.5 MHz frequency band
Light Source
- Socket Type
- GU10
- Wattage
- 4.2 W
- E
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.5
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 400 lumens
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Included Accessories
- Power adapter, network cable, Hue switch, Hue bridge
- Package
- Box
- IP20
- Warranty
- 2 years
- 410 g
- Dimensions & Weight Details
- Light bulb height: 5.7 cm x diameter: 5 cm - 50 g , Wireless bridge - width: 88 mm x depth: 88 mm x height: 26 mm , Switch - 37 g
- Shipping Dimensions (WxDxH) / Weight
- 21.9 cm x 17.6 cm x 14 cm / 820 g
- -20 °C
- 45 °C
