Philips Hue 4.2W GU10 Colour Smart LED 3-Pack Bulbs Starter Kit
Quicklinx: J1D2WS00 Mfr#: 929003666510
Hurry, only 2 left in stock!
£141.66 ex VAT
£169.99 inc VAT
The Philips Hue white and color ambiance contains 3 bulbs, a bridge and a switch. It can transform your lighting into an extraordinary experience with colored and white light. Sync lights to your music, TV and games for immersive effects.
  • Be creative with colors
    Play with light and choose from 16 million colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Sync with music and films
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm. Download the third-party apps and discover the amazing things you can do with Philips Hue.
  • Light up your gaming
    Lift your gaming experience to the next level. Download the third party apps and discover the amazing things you can do with Philips Hue.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like to, helping you start your day feeling refreshed. The light brightness increases gradually, mimicking the effect of sunrise, and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day the right way. In the evening, the relaxing warm white light helps you to unwind, relax and prepare your body for a good night's sleep.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of summer sun or the ice cool daylight of winter.
Philips Hue White and Color Ambiance Starter Kit - wireless lighting set - LED spot light bulb x 3 - GU10 - 4.2 W - multicolour/warm to cool white light - 2000-6500 K
Wireless lighting set
Light Source Type
3 x LED spot light bulb
Supported Light Bulbs Qty
50
Dimmer
Socket Type
GU10
Wattage
4.2 W
Energy Efficiency Class
E
Colour of Illumination
Multicolour/warm to cool white light
Colour Temperature
2000-6500 K
Luminous Power
400 lumens
Intelligent Assistant
Cortana, Google Assistant, Alexa - indirect
Platform
Apple HomeKit, Hue
Communications Technology
Bluetooth, Zigbee
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Dimmer
Android compatible, iOS compatible, controlled via Bluetooth, app-controlled, voice control, 2400 - 2483.5 MHz frequency band
Light Source
Socket Type
GU10
Wattage
4.2 W
E
Energy Consumption per 1000h
5 kWh
Power Factor
0.5
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
400 lumens
Lifetime
25000 hours
Switch Cycles
50000
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Included
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Voice Controlled
Indirect
Power adapter, network cable, Hue switch, Hue bridge
Package
Box
IP20
Warranty
2 years
410 g
Dimensions & Weight Details
Light bulb height: 5.7 cm x diameter: 5 cm - 50 g , Wireless bridge - width: 88 mm x depth: 88 mm x height: 26 mm , Switch - 37 g
21.9 cm x 17.6 cm x 14 cm / 820 g
-20 °C
45 °C
Brand: Philips
