Philips Hue 4.2W GU10 Colour Smart LED 3-Pack Bulbs
Quicklinx: J1D0WS00 Mfr#: 929003666503
Hurry, only 1 left in stock!
£108.33 ex VAT
£129.99 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
The Philips Hue White and Color Ambiance light bulb offers versatility through its multicolor capability, allowing users to customize their lighting for any occasion. Compatible with various intelligent assistants such as Alexa, Google Assistant, and Apple HomeKit, this bulb provides seamless integration into existing smart home systems. With a light output of 400 lumens and a color temperature range of 2000-6500 K, it ensures both vibrant colors and warm whites, perfect for enhancing the atmosphere in any room. Designed with energy efficiency in mind, the bulb operates at just 4.2 W while providing a wattage equivalent of 50 W. It boasts a long lifetime of 25,000 hours, along with 50,000 switch cycles, making it a reliable choice for energy-conscious consumers. The Philips Hue App allows for personalized control, enabling users to dim the light and adjust colors with ease. This bulb is a functional lighting solution and a stylish addition to any living space.
  • Innovative smart technology
    The Philips Hue White and Color Ambiance light bulb is IoT-compatible, enabling control through various intelligent assistants like Cortana and Apple HomeKit, integrating into smart home ecosystems.
  • Versatile lighting options
    This bulb offers a wide color temperature range from warm white to daylight, allowing for customization in lighting ambiance across different settings in the home.
  • Energy-efficient design
    Operating at just 4.2 W while producing 400 lumens, the Philips Hue bulb provides significant energy savings while retaining excellent performance.
  • Long-lasting performance
    With a rated lifetime of 25,000 hours and capable of enduring 50,000 switch cycles, this light bulb is designed for durability and reduces the need for frequent replacements.
Philips Hue White and Color Ambiance - LED spot light bulb - GU10 - 4.2 W - multicolour/cold white/warm white to daylight - 2000-6500 K (pack of 3)
Light Source Type
LED spot light bulb
Packaged Quantity
3 (specifications are for single item)
Socket Type
GU10
Wattage
4.2 W
Wattage Equivalent
50 W
Energy Efficiency Class
E
Colour of Illumination
Multicolour/cold white/warm white to daylight
Colour Temperature
2000-6500 K
Luminous Power
400 lumens
Beam Angle
40 degree(s)
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa, Apple HomeKit
Platform
Hue
Light Source Voltage
AC 220-240 V
Packaged Quantity
Light Source
LED spot light bulb
Socket Type
GU10
Wattage
4.2 W
Wattage Equivalent
50 W
E
Energy Consumption per 1000h
5 kWh
Power Factor
0.5
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
400 lumens
Beam Angle
40 degree(s)
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Power Requirements
AC 220-240 V
4.2 Watt
Power Consumption Stand by
0.25 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Package
Box
50 mm
57 mm
Diameter
50 mm
Length
50 mm
50 g
7.2 cm x 7.2 cm x 17.4 cm / 190 g
Type: Light bulb
Compatible With: Alexa
Compatible With: Apple HomeKit
Compatible With: Cortana
Brand: Philips
