Philips Hue 100W Power Supply
Quicklinx: GW0LWS00 Mfr#: 915005923201
Fill your entire outdoor space with smart light using this outdoor power supply, which allows you to add up to 100 W of different lights. Connect two cables - each measuring up to 30 meters - to any low-voltage outdoor Philips Hue light on each connector, adding each fixture's wattage to reach the maximum 100 W threshold of the power supply.
Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio. You can do it yourself, using Hue spots or bollards. The products are based on low voltage, safe to use and easy to install. No more complexity to get lighting outdoors: start to create and extend to suit your needs.
Philips Hue power supply - 100 Watt
Power supply
7 cm x 20 cm x 4.5 cm
1.1 kg
United Kingdom
(50 - 60 Hz)
Power Provided
100 Watt
Cables
Power extension cable
Power supply
Outdoor lighting system
7 cm
20 cm
4.5 cm
1.1 kg
Enclosure Colour
United Kingdom
(50 - 60 Hz)
Input Connectors
Power Type G
Input Connectors Qty
1
Power Provided
100 Watt
Weatherproof
Material
Synthetic
IP67
Shipping Width
23.6 cm
Shipping Depth
8.2 cm
Shipping Height
13.4 cm
Shipping Weight
1.245 kg
