Philips Headphone Stereo 0334
Quicklinx: 8BMYWS00 Mfr#: LFH0334/00
Recommended Use: [N/A]
Connectivity: Wired
Earcover : Binaural
16 left in stock
£45.65 ex VAT
£54.78 inc VAT
Outstanding audio quality with Philips transcription headphones
The lightweight under-the-chin style headphones with dual sound system are designed to deliver excellent sound quality, with soft ear cushions for wearing comfort, and a hanging bracket that attaches the headset to a monitor.
Superior audio quality
  • A 14 mm speaker driver optimizes high audio quality
  • Gold-plated plug ensures an ultra-reliable connection
  • Neodymium magnet enhances sensitivity and sound quality
For optimal results
  • Lightweight design improves comfort for prolonged use
  • Under chin style to fit all ears for better comfort
  • 3 meter/10-foot cable for freedom to move about your work area
Small enough for optimum wearing comfort, yet large enough to deliver crisp, non-distorted sound, the 14 mm speaker driver is the ideal size to deliver high quality sound.
The precious-metal gold finishing on the plug will produce a more reliable connection for better audio quality.
Neodymium is the best material for producing a strong magnetic field for greater sensitivity and higher overall sound quality.
The durable, lightweight quality materials enhance comfort for extended wearing.
Designed for an under-the-chin fit for better comfort.
The 3 meter/10-foot cable gives you the freedom to move around your work area without having to remove the headphones.
  • Gold-plated plug ensures an ultra reliable connection
Philips LFH0334 - headphones
Headphones - wired - 3.5 mm jack
Headphones Form Factor
Under-chin
Wired
Headphones Technology
Dynamic
Sound Output Mode
Stereo
Audio Specifications
Sensitivity 103 dB
Diaphragm Type
PET
Audio Output
Under-chin
Dynamic
Wired
Sound Output Mode
Stereo
Sensitivity
103 dB
Diaphragm
PET - 14 mm
Magnet Material
Neodymium
Connector Type
Headphones (mini-phone stereo 3.5 mm)
Cable
Plated Connector
Gold
Cable Details
Headphones cable - 3 m
Connectivity: Wired
Earcover : Binaural
Brand: Philips
Stock Status: While stocks last
Stock Status: Clearance
