Philips Gradient PC strip 24 27 inch EU SK
Quicklinx: HWZNWS00 Mfr#: 929003498502
£140.44 ex VAT
£168.52 inc VAT
Experience the thrill of the cinema at home with the Philips Hue Play gradient lightstrip. Get multiple colors of light that react to the content on your screen.
  • Seamlessly blend colors
    Get a seamless blend of multiple colors of light at the same time in a single LED strip. The colors flow together naturally, casting light against the wall to showcase a unique effect behind your TV.
  • Surround lighting effects
    Experience the magic of surround lighting! With 45-degree light projection, the Play gradient lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience.
  • Game-changing home entertainment
    Philips Hue is the only smart lighting brand to easily sync your color-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colorful full-room experience.
  • Easy installation
    The Philips Hue Play gradient lightstrip is specially designed for television entertainment.
Philips Hue Play Gradient - light strip - LED - 15 W - multicolour/white light - black
Light strip
Light Source Type
LED
Light Cover Type
Diffuser
Wattage
15 W
Colour of Illumination
Multicolour/white light
Luminous Power
740 lumens
Number of LEDs
50
Intelligent Assistant
Google Assistant - indirect
Platform
Hue
Communications Technology
Bluetooth
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Light strip
Light Cover Type
Diffuser
Android compatible, iOS compatible, diffused light effect, app-controlled, Hue Sync technology, desktop aquarium compatible, 24" - 27" monitor compatible
Light Source
LED
Built-in LED Lamp
Wattage
15 W
Luminous Power
740 lumens
Number of LEDs
50
Lifetime
25000 hours
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App, Philips Hue Sync app
Supported Host Device Platform
iOS, Android
Bluetooth
Google Assistant
Voice Controlled
Indirect
Product Material
Silicone
Body Colour
Power adapter, mounting brackets
Package
Box
IP20
Warranty
2 years / 30 days return
1.7 cm
1.6 cm
Length
90.5 cm
203 g
29 cm x 29 cm x 14 cm / 1.38 kg
-20 °C
45 °C
Brand: Philips
