Philips Evnia 8000 49" QD OLED Gaming Monitor
Quicklinx: HTTWWS00 Mfr#: 49M2C8900L/00
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 0.03ms
Speakers: Speakers with subwoofer
Interfaces: USB-C, DisplayPort, HDMI
£673.98 ex VAT
£808.77 inc VAT
Experience luxurious gaming with this monitor's colourful QD OLED display, incredible DisplayHDR TrueBlack 400 certification and booming DTS Sound speakers. This monitor is likely to give you a gaming escapade that's hard to forget.
Philips Evnia 8000 49M2C8900L - OLED monitor - curved - 49" - HDR
OLED monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1814961
Energy Class
Class G
Curved Screen
Adaptive-Sync Technology
AMD FreeSync Premium Pro, AMD Adaptive-Sync
USB Hub, KVM Switch, USB PD 90 watt
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 (DisplayPort: 144 Hz, HDMI: 60 Hz)
Pixel Pitch
0.233 mm
Brightness
1000 cd/m²
Contrast Ratio
1000000:1
HDR Capable
DisplayHDR 400 True Black
Response Time
0.03 ms (grey-to-grey)
Gaming
Colour Support
1.07 billion colours
Colour Gamut
99% DCI-P3 (CIE 1976), 127.4% NTSC (CIE 1976), 153.1% sRGB (CIE 1931), 125.2% Adobe RGB (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating
Voltage
AC 100-240 V (50/60 Hz)
White
Dimensions (WxDxH) - with stand (highest position)
119.5 cm x 35.9 cm x 54.4 cm
13.96 kg
Plug and Play, FCC Class B certified, ICES-003, CB, DDC/CI, RoHS, TUV Bauart, EAC, BFR-free, USB Power Delivery 3.0, PVC-free, Mercury-free, TUV/ISO 9241-307
3-year warranty
Display Type
OLED monitor / Quantum Dot OLED
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
49"
Viewable Size
48.9"
Curved Screen
Yes (1800R)
Built-in Devices
USB Hub, KVM Switch
USB Power Delivery
90 watt
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
108.77
Brightness
1000 cd/m²
Contrast Ratio
1000000:1
HDR Certification
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 144 Hz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture by picture, MultiView, SmartContrast, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, DTS Sound, sRGB Color Space, Low Input Lag, EasyRead, Picture-in-Picture, Delta E<2 calibration, 10-bit Colour Depth, Multiple HDR Mode, 3-sided Ambiglow, LowBlue Mode, RGB Q-Stripe, VESA Certified ClearMR 8000, Stark ShadowBoost
White
119.5 cm x 35.9 cm x 54.4 cm - with stand (highest position)
13.96 kg
Audio
Output Power / Channel
7.5 watt
2 x HDMI , DisplayPort 1.4 , USB-C (DisplayPort Alt Mode, power up to 90W) , Audio line-out
Mechanical
Tilt Angle
-5/+15
Swivel Angle
40
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 100% recyclable packaging, textured finish
Remote control, VESA bracket
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB upstream cable , USB-C to USB-C cable
MTBF
30,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
65 kWh/1000h
Power Consumption HDR (On mode)
85 kWh/1000h
Power Consumption (Typical)
156.5 watt
Power Consumption Stand by
0.5 watt
Apple MacOS X, Windows 8 / 8.1 / 10 / 11
Dimensions & Weight Details
With stand (highest position) - width: 119.5 cm - depth: 35.9 cm - height: 54.4 cm - weight: 13.96 kg , Without stand - width: 119.5 cm - depth: 18.1 cm - height: 36.9 cm - weight: 10.82 kg
Shipping Width
129 cm
Shipping Depth
30 cm
Shipping Height
47.5 cm
Shipping Weight
19.41 kg
Limited warranty - 3 years
20 - 80% RH
Diagonal Size: 49in
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Philips
Price Range Ex VAT: £500 - £750
