Philips Evnia 5000 32" QHD Curved Gaming Monitor
Quicklinx: HTTYWS00 Mfr#: 34M1C5500VA/00
This Philips gaming monitor delivers crystal-clear visuals and smooth gameplay. Sync technology, 165 Hz refresh rate with HDR create a lifelike experience. The slim-frame display with Ultra Wide-Color enhances visual immersion.
  • Built-in stereo speakers for multimedia
    A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
  • MultiView enables simultaneous dual connection and view
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Tilt, swivel and height-adjust for an ideal viewing position
    The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
  • EasySelect menu toggle key for quick on-screen menu access
    The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the On-Screen Display menu.
  • LowBlue mode and Flicker-free easy-on-the eyes viewing
    Our LowBlue Mode and Flicker-free technology have been developed to reduce eye strain and fatigue often caused by long hours in front of a monitor.
  • SmartImage HDR gives optimal viewing from your HDR content
    Select one of SmartImage HDR modes to best suit your needs. HDR Game: optimised for playing video games. With brighter white and darker black, the gaming scene is vivid and reveals more details, easily spot enemies hiding in the dark corners and shadows. HDR Movie: ideal for watching HDR movie. Delivers better contrast and brightness for a more realistic and immersive viewing experience. HDR Photo: enhanced red, green and blue for lively visuals. DisplayHDR: VESA DisplayHDR certified*. Personal: customised settings in picture menu.*Please refer to specification for HDR grade.
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
    These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
  • VA display delivers awesome images with wide viewing angles
    The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
  • Curved display design for more immersive experience
    Desktop monitors offer a personal user experience, which suits a curve design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the center of your desk.
  • 165 Hz refresh rates for ultra-smooth, brilliant images
    You play intense, competitive gaming. You demand display with lag free, ultra-smooth images. This Philips display redraws the screen image up to 165 times per second, effectively faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With 165 Hz frame rate, you get those critical missing images on the screen which shows enemy movement in ultra-smooth motion so you can easily target them. With ultra-low input lag and no screen tearing, this Philips display is your perfect gaming partner
  • AMD FreeSync Premium; tear free, stutter free, fluid gaming
    Gaming shouldn't be a choice between choppy gameplay or broken frames. AMD FreeSync Premium equips serious gamers with a fluid, tear-free gameplay experience at peak performance. There are no compromises, game confidently with a high refresh rate, low framerate compensation and low latency.
  • 1 ms (MPRT) fast response for crisp images and smooth gameplay
    MPRT (motion picture response time) is a more intuitive way to describe response time, which directly refers to the duration between seeing blurry noise and clean, crisp images. The Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur and delivers sharper and more precise visuals to enhance your gaming experience. The best choice for playing thrilling and twitch-sensitive games.
  • Low input lag reduces time delay between devices to monitor
    Input lag is the amount of time that elapses between performing an action with connected devices and seeing the result on screen. Low input lag reduces the time delay between entering a command from your devices to monitor, greatly improving play on twitch-sensitive video games, particularly important for playing fast-paced, competitive games.
Philips Evnia 5000 34M1C5500VA - LED monitor - curved - 34" - HDR
LED-backlit LCD monitor - 34"
Energy Class
Class F
Curved Screen
Adaptive-Sync Technology
USB 3.2 Gen 1 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 (DisplayPort: 165 Hz, HDMI: 100 Hz)
Pixel Pitch
0.23175 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours (8-bit)
Colour Gamut
100% NTSC (CIE 1976), 120.7% sRGB (CIE 1931)
Input Connectors
2xHDMI, 2xDisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) - with stand (highest position)
80.8 cm x 30.8 cm x 61.8 cm
8.56 kg
Plug and Play, FCC Class B certified, ICES-003, CB, DDC/CI, ISO 9241-307, TUV Bauart, CU-EAC, BFR-free, HDCP 2.2, HDCP 1.4, PVC-free, 2012/19/EU, Mercury-free, EAEU RoHS
3-year warranty
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB 3.2 Gen 1 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.23175 mm
Pixel Per Inch
109.68
Brightness
300 cd/m²
Contrast Ratio
3000:1
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 165 Hz
Horizontal Refresh Rate
30 - 250 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
MultiView, Crystal Clear, SmartContrast, SmartImage Game, Flicker Free technology, PBP, Low Input Lag, EasyRead, 3-sided bezeless, PIP support, SmartImage HDR, LowBlue Mode, LED power indicator
80.8 cm x 30.8 cm x 61.8 cm - with stand (highest position)
8.56 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
2 x DisplayPort 1.4 , 2 x HDMI , Audio line-out , 2 x USB 3.2 Gen 1 downstream , 2 x USB 3.2 Gen 1 downstream (BC 1.2) , USB-B 3.2 Gen 1 upstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), 100% recyclable packaging, textured finish
HDMI cable , DisplayPort cable , USB upstream cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31 kWh/1000h
Power Consumption HDR (On mode)
62 kWh/1000h
Power Consumption (Typical)
31.3 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Dimensions & Weight Details
With stand (highest position) - width: 80.8 cm - depth: 30.8 cm - height: 61.8 cm - weight: 8.56 kg , Without stand - width: 80.8 cm - depth: 10.7 cm - height: 36.6 cm - weight: 7.05 kg
Shipping Width
98 cm
Shipping Depth
22.6 cm
Shipping Height
52.6 cm
Shipping Weight
11.5 kg
Limited warranty - 3 years
20 - 80%
