Philips Evnia 5000 27" QHD Curved Gaming Monitor
Quicklinx: HTTXWS00 Mfr#: 27M1C5500VL/00
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 1ms
Interfaces: HDMI, DisplayPort
£170.13 ex VAT
£204.15 inc VAT
This Philips gaming monitor delivers crystal-clear visuals and smooth gameplay. Sync technology, 165 Hz refresh rate with HDR create a lifelike experience. The slim-frame display with Ultra Wide-Color enhances visual immersion.
  • EasySelect menu toggle key for quick on-screen menu access
    The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the On-Screen Display menu.
  • LowBlue mode and Flicker-free easy-on-the eyes viewing
    Our LowBlue Mode and Flicker-free technology have been developed to reduce eye strain and fatigue often caused by long hours in front of a monitor.
  • SmartImage HDR gives optimal viewing from your HDR content
    Select one of SmartImage HDR modes to best suit your needs. HDR Game: Optimize for playing video games. With brighter white and darker black, the gaming scene is vivid and revealing more details, easily spot enemies hiding in the dark corner and shadows. HDR Movie: Ideal for watching HDR movie. Deliver better contrast and brightness for more realistic and immerse viewing experience. HDR Photo: Enhance red, green, and blue for lively visuals. DisplayHDR: VESA DisplayHDR certified*. Personal: Customize settings in picture menu.*Please refer to specification for HDR grade.
  • VA display delivers awesome images with wide viewing angles
    Philips VA LED display uses an advanced multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. It's optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images.
  • Curved display design for more immersive experience
    Desktop monitors offer a personal user experience, which suits a curve design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the center of your desk.
  • Crystalclear images with Quad HD 2560 x 1440 pixels
    These Philips screens deliver Crystalclear, Quad HD 2560x1440 or 2560x1080 pixel images. Utilizing high performance panels with high density pixel count, enabled by high bandwidth sources like USB-C, Displayport, HDMI, these new displays will make your images and graphics come alive. Whether you are demanding professional requiring extremely detailed information for CAD-CAM solutions, using 3D graphic applications or a financial wizard working on huge spreadsheets, Philips displays will give you Crystalclear images.
  • 1ms (MPRT) fast response for crisp image and smooth gameplay
    MPRT (motion picture response time) is more intuitive way to describe the response time, which directly refers the duration from seeing blurry noise to clean and crisp images. Philips gaming monitor with 1 ms MPRT effectively eliminates smearing and motion blur, delivers shaper and precise visuals to enhance gaming experience. Best choice for playing thrilling and twitch-sensitive games.
  • Low input lag reduces time delay between devices to monitor
    Input lag is the amount of time that elapses between performing an action with connected devices and seeing the result on screen. Low input lag reduces the time delay between entering a command from your devices to monitor, greatly improve on playing twitch-sensitive video games, particularly important to whom plays fast-paced, competitive games.
  • 165Hz refresh rates for ultra-smooth, brilliant images
    You play intense, competitive gaming. You demand display with lag free, ultra-smooth images. This Philips display redraws the screen image up-to 165 times per second, effectively faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With 165Hz frame rate, you get those critical missing images on the screen which shows enemy movement in ultra-smooth motion so you can easily target them. With ultra-low input lag and no screen tearing, this Philips display is your perfect gaming partner
  • SmartImage game mode optimized for gamers
    The new Philips gaming display has quick access OSD fine tuned for gamers, offering you multiple options."FPS" mode (First person shooting) improves dark themes in games, allowing you to see hidden objects in dark areas."Racing" mode adapts display with fastest response time, high color, along with image adjustments."RTS" mode (Real time strategy) has a special SmartFrame mode which enables highlighting of specific area and allows for size and image adjustments. Gamer 1 and Gamer 2 enable you to save personal customized settings based on different games, ensuring best performance.
Philips Evnia 5000 27M1C5500VL - LED monitor - curved - QHD - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class F
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 (DisplayPort: 165 Hz, HDMI: 144 Hz)
Pixel Pitch
0.2331 mm
Brightness
250 cd/m²
Contrast Ratio
4000:1
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey), 1 ms (MPRT)
Gaming
Colour Support
16.7 million colours
Colour Gamut
95.6% NTSC (CIE 1976), 126.5% sRGB (CIE 1931)
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
Textured black
61.1 cm x 19.3 cm x 44.7 cm
5.49 kg
HDCP 2.2, HDCP 1.4, FCC Class B certified, PVC-free, Mercury-free, BFR-free, Plug and Play, CB, ICES-003, CU-EAC, EAEU RoHS, TUV, ISO 9241-307, TUV Bauart
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
27"
Curved Screen
Yes (1500R)
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Pixel Per Inch
108.79
Brightness
250 cd/m²
Contrast Ratio
4000:1
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 144 Hz
Horizontal Refresh Rate
30 - 250 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Brazilian Portuguese, Chinese (simplified), Chinese (traditional), Czech, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Korean, Polish, Portuguese, Russian, Spanish, Swedish, Turkish, Ukrainian
Crystal Clear UltraWide QHD, Low Input Lag, LowBlue Mode, EasyRead, Adaptive-Sync technology, Flicker Free technology, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, SmartImage HDR, Wide Viewing Angle
Textured black
61.1 cm x 19.3 cm x 44.7 cm - with stand
5.49 kg
2 x HDMI , DisplayPort 1.4
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x HDMI cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
26 kWh/1000h
Power Consumption HDR (On mode)
46 kWh/1000h
Power Consumption (Typical)
38.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10 / 11
Dimensions & Weight Details
With stand - width: 61.1 cm - depth: 19.3 cm - height: 44.7 cm - weight: 5.49 kg , Without stand - width: 61.1 cm - depth: 8.3 cm - height: 36.6 cm - weight: 4.18 kg
Shipping Width
73 cm
Shipping Depth
22.6 cm
Shipping Height
46.9 cm
Shipping Weight
9.2 kg
35 °C
20 - 80%
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Philips
