Philips Evnia 42" 4K OLED 138Hz Gaming monitor
Quicklinx: HTRTWS00 Mfr#: 42M2N8900/00
Diagonal Size: 42in
Max Resolution: 3840 x 2160
Response Time: 0.1ms
Speakers: Speaker(s)
Interfaces: HDMI, USB-C, DisplayPort
Hurry, only 1 left in stock!
£915.84 ex VAT
£1,099.00 inc VAT
Be prepared to get stunned by the precise colour reproduction of the Evnia OLED gaming monitor. The innovative Ambiglow redefines what a gaming environment usually is, levelling up not only your game gear, but also your gaming experience.
Philips Evnia 8000 42M2N8900 - OLED monitor - 4K - 42" - HDR
OLED monitor - 42"
Energy Class
Class G
Adaptive-Sync Technology
AMD Adaptive-Sync
KVM Switch, USB PD 90 Watt
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2395 mm
Brightness
450 cd/m²
Contrast Ratio
15000000:1
HDR Capable
HDR10
Response Time
0.1 ms (grey-to-grey)
Gaming
Colour Support
1.07 billion colours
Colour Gamut
98.5% DCI-P3 (CIE 1976), 110.3% NTSC (CIE 1976), 131.3% sRGB (CIE 1931), 93.6% Adobe RGB (CIE 1976)
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, low reflection coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
White
Dimensions (WxDxH) - with stand (highest position)
93.2 cm x 35.9 cm x 68.9 cm
17.3 kg
Plug and Play, FCC Class B certified, ICES-003, CB, DDC/CI, RoHS, TUV Bauart, cETLus, CU-EAC, BFR-free, HDCP 2.2, HDCP 1.4, PVC-free, HDCP 2.3, Mercury-free, EAEU RoHS, TUV/ISO 9241-307
3-year warranty
Display Type
OLED monitor / OLED
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
42"
Viewable Size
41.54"
AMD Adaptive-Sync
Built-in Devices
KVM Switch
USB Power Delivery
90 Watt
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160
Pixel Pitch
0.2395 mm
Pixel Per Inch
106.06
Brightness
450 cd/m²
Contrast Ratio
15000000:1
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
48 - 138 Hz
Horizontal Refresh Rate
30 - 255 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture by picture, MultiView, FPS Mode, SmartImage Game, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, RTS Mode, DTS Sound, sRGB Color Space, Low Input Lag, EasyRead, Ultra Wide-Color Technology, Racing Mode, Picture-in-Picture, Delta E<2 calibration, 10-bit Colour Depth, 3-sided Ambiglow, LowBlue Mode, RGB Q-Stripe
White
93.2 cm x 35.9 cm x 68.9 cm - with stand (highest position)
17.3 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
2 x HDMI (HDCP 2.3) , DisplayPort 1.4 (HDCP 2.3) , USB-C (HDCP 2.3, data, power up to 90W) , USB-B 3.2 Gen 1 upstream (Type B) , 2 x USB 3.2 Gen 1 downstream , 2 x USB 3.2 Gen 1 downstream with Battery Charging 1.2 (fast charging) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+15
Swivel Angle
40
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
Remote control, VESA bracket
1 x DisplayPort cable , 1 x HDMI cable , 1 x USB upstream cable , 1 x USB-C to USB-C cable
MTBF
30,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
51 kWh/1000h
Power Consumption HDR (On mode)
79 kWh/1000h
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand (highest position) - width: 93.2 cm - depth: 35.9 cm - height: 68.9 cm - weight: 17.3 kg , Without stand - width: 93.2 cm - depth: 7.9 cm - height: 53.5 cm - weight: 13.84 kg
Shipping Width
107 cm
Shipping Depth
18.8 cm
Shipping Height
63.5 cm
Shipping Weight
21.01 kg
Limited warranty - 3 years
20 - 80%
Diagonal Size: 42in
Interfaces: HDMI
Interfaces: USB-C
Interfaces: DisplayPort
Brand: Philips
Price Range Ex VAT: £750 - £1000
