The Philips 27" (68.6 cm) 4K UHD monitor gives ultra-clear picture quality. 4K UHD with wide view delivers the same ultimate clarity and lifelike visuals from any front-angle view. Flicker-free to reduce eye fatigue after prolonged use.
Eco-friendly materials meet major international standards
"Philips is committed to use sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In some selected models we utilize upto 65% post consumer recycled plastics. Strict adherence to RoHS standards ensure substantial reduction or elimination of toxic substances like Lead, for example. Mercury content in monitors with CCFL backlight has been reduced significantly, while eliminated in monitors with LED backlight completely. -
Less eye fatigue with Flicker-free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
LowBlue Mode for easy on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
HDMI for quick digital connection
Enjoy crisp colorful images and audio with simple one-cable connection. An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality smooth digital video (up to 4K/UHD resolution at 60 Hz) and audio all transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
Narrow border display for a seamless appearance
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. -
IPS LED wide view technology for image and colour accuracy
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
UltraClear 4K UHD (3840x2160) resolution for precision
These Philips displays utilize high performance panels to deliver UltraClear, 4K UHD (3840 x 2160) resolution images. Whether you are demanding professional requiring extremely detailed images for CAD solutions, using 3D graphics applications or a financial wizard working on huge spreadsheets, Philips displays will make your images and graphics come alive.
- Philips E-line 276E8VJSB - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/420484
- Energy Class
- Class F
- Energy Consumption per Year
- 61 kWh
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.155 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, UltraClear, 3H Hard Coating, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy gunmetal black
- 61.3 cm x 18.9 cm x 46.6 cm
- 4.84 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, VCCI, BSMI, ICES-003, CCC, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, CECP, CEL, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.2
- Display Type
- Energy Class
- Class F
- 61 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.155 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 59 - 61 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Multilingual
- Picture by picture, Sync on Green, MultiView, Low Blue Light Mode, Flicker Free technology, Ultra Narrow Border, sRGB Mode, Picture-in-Picture
- 61.3 cm x 18.9 cm x 46.6 cm - with stand
- 4.84 kg
- DisplayPort , 2 x HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Security lock slot (cable lock sold separately), mercury free
- Cables Included
- HDMI cable
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 26.1 kWh/1000h
- Power Consumption (Typical)
- 19.9 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 61.3 cm - depth: 18.9 cm - height: 46.6 cm - weight: 4.84 kg , Without stand - width: 61.3 cm - depth: 4.1 cm - height: 37.4 cm - weight: 4.23 kg
- Shipping Width
- 66 cm
- Shipping Depth
- 13.5 cm
- Shipping Height
- 52.3 cm
- Shipping Weight
- 6.53 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 20 - 80%
