UltraColor technology delivers a wider spectrum of colors for a more brilliant picture. UltraColor wider color gamut produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive and vivid colors from UltraColor technology. IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colors, making them ideal not only for photos, movies and web browsing, but also for professional applications that demand color accuracy and consistent brightness at all times.
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a perfect solution to regulate brightness and reduce flicker for more comfortable viewing. SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for perfect digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
The discreetly placed EasySelect menu toggle key allows you to make quick and easy adjustments to monitor settings in the on-screen display menu. SmartImage Lite is an exclusive Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press of a single button.
Built-in stereo speakers
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
16:9 Full HD display
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture. -
SmartImage Lite
SmartImage Lite is an exclusive, leading edge Philips technology that analyses the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, colour saturation and sharpness of images and videos for ultimate display performance- all in real time with the press of a single button. -
SmartContrast
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption. -
MHL technology
Mobile High-Definition Link (MHL) is a mobile audio/video interface for directly connecting mobile phones and other portable devices to high-definition displays. An optional MHL cable allows you to simply connect your MHL-capable mobile device to this large Philips MHL display and watch your HD videos come to life with full digital sound. Now not only can you enjoy your mobile games, photos, movies or other apps on its big screen, you can simultaneously charge your mobile device so you never run out of power halfway. -
EasySelect Menu Toggle Key
The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the On-Screen Display menu. -
Ultra Wide-Color Technology
Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology. -
IPS technology
IPS displays use an advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle. Unlike standard TN panels, IPS displays give you remarkably crisp images with vivid colours, making them ideal not only for Photos, movies and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
- Philips E-line 276E7QDAB - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 46 kWh
- Power Consumption (On mode)
- 31 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, HDMI (MHL)
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Glossy black
- 61.6 cm x 17.9 cm x 46.8 cm
- 4.33 kg
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV, VCCI, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, CECP, RCM, CU-EAC
- Display Type
- Energy Class
- Class B
- 46 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, SmartImage Lite, SmartContrast, Flicker Free technology, Mercury free, Wide Viewing Angle, EasySelect Menu Toggle Key, UltraColor technology
- Glossy black
- 61.6 cm x 17.9 cm x 46.8 cm - with stand
- 4.33 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- VGA , DVI-D (HDCP) , MHL / HDMI (HDCP) , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 50,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- 31 W
- Power Consumption (Typical)
- 17.03 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- On / Off Switch
- No
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
- Dimensions & Weight Details
- With stand - width: 61.6 cm - depth: 17.9 cm - height: 46.8 cm - weight: 4.33 kg , Without stand - width: 61.6 cm - depth: 5.2 cm - height: 37 cm - weight: 4.08 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
