Philips E-Line 22"Full HD LED Monitor VGA DVI HDMI
Quicklinx: CVBSWS00 Mfr#: 227E7QDSB/00
This brilliant wide view display offers vivid colors and crisp details wrapped in an elegance-inspired design for a light and fresh face in any home or office.
  • AH-IPS technology
    AH-IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle. Unlike standard TN panels, AH-IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times.
  • 16:9 Full HD display
    Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colors expect a true to life picture.
  • Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a solution to regulate brightness and reduce flicker for more comfortable viewing.
  • SmartContrast
    SmartContrast is a Philips technology that analyzes the contents you are displaying, automatically adjusting colors and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
  • SmartImage Lite
    SmartImage Lite is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage Lite dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
  • UltraNarrow border
    Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setup like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • EasySelect menu toggle key
    The discreetly placed EasySelect Menu Toggle Key allows you to make quick and easy adjustments to monitor settings in the OnScreen Display menu.
  • Mercury free
    Philips monitors with LED backlighting are free of Mercury content, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its life-cycle, from manufacturing to disposal.
Philips E-line 227E7QDSB - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, HDMI (MHL)
Display Position Adjustments
Tilt
Voltage
Glossy black
49.9 cm x 21.3 cm x 39.8 cm
2.96 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV, VCCI, C-Tick, SASO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, KUCAS, CECP, EPA, cETLus, CU
Display Type
Energy Class
Class A
26 kWh
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
AH-IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, sRGB colour management, SmartImage Lite, SmartResponse, SmartContrast, edge-to-edge glass, Flicker Free technology, Ultra Narrow Border, Mercury free, Wide Viewing Angle, EasySelect Menu Toggle Key
Glossy black
49.9 cm x 21.3 cm x 39.8 cm - with stand
2.96 kg
MHL / HDMI (HDCP) , DVI-D (HDCP) , VGA (HD-15) , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
18 W
Power Consumption (Typical)
17.04 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 49.9 cm - depth: 21.3 cm - height: 39.8 cm - weight: 2.96 kg , Without stand - width: 49.9 cm - depth: 5 cm - height: 30.6 cm - weight: 2.71 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
