Philips Brilliance P-line 499P9H 49" 5120x1440 5ms HDMI DisplayPort USB-C Curved LED Monitor
Quicklinx: F721WS00 Mfr#: 499P9H/00
Diagonal Size: 49in
Max Resolution: 5120 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort, HDMI
11 In Stock
£804.98 ex VAT
£965.97 inc VAT
Wide open possibilities with two high-performance monitors in one
Our award-winning 49" curved 32:9 SuperWide display is like two full-size high-performance monitors in one. Productivity-enhancing features like USB-C and pop-up webcam with Windows Hello deliver the performance and convenience you expect.
  • 1800r curved display for a more immersive experience
    Innovative curved display offers less image distortion, a wider field of view, reduced glare, and more comfort for eyes.
  • Securely sign in with pop-up webcam with Windows Hello
    Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • DisplayHDR 400 for more lifelike and outstanding visuals
    VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike other'HDR-compatible' screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and minimum 400 nits of brightness, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
  • Tilt, swivel and height-adjust for an ideal viewing position
    The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
  • 32:9 SuperWide screen designed to replace multiscreen setups
    32:9 SuperWide 49" screen, with 5120 x 1440 resolution, is designed to replace multiscreen setups for massive wide view. It's like having two 27" 16:9 Quad HD displays side-by-side. SuperWide monitors offer screen area of dual monitors without the complicated setup.
  • MultiView enables simultaneous dual connection and view
    With the ultra-high resolution Philips MultiView display you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multi-tasking.
  • Effortlessly smooth action with Adaptive-Sync technology
    Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artifact-free performance at virtually any framerate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Less eye fatigue with Flicker-free technology
    Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-free Technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
  • Built-in KVM switch to easily switch between sources
    With MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse set up. A convenient button allows you to quickly switch between sources. Handy with set-ups that require dual PC computing power or sharing one large monitor to show two different PCs.
  • Built in USB-C docking station
    This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Simplify by connecting all your peripherals like keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook and this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data, while powering up and re-charging your notebook at the same time.
Philips Brilliance P-line 499P9H - LED monitor - curved - 49" - HDR
LED-backlit LCD monitor - 49"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/398394
Energy Class
Class G
Energy Consumption per Year
114 kWh
Power Consumption (On mode)
52 W
Curved Screen
Microphone, KVM Switch, USB 3.1 hub, 1080p webcam, USB PD 90 Watt
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Dual Quad HD 5120 x 1440 at 60 Hz
Pixel Pitch
0.233 mm
Brightness
450 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
103% NTSC, 121% sRGB, 91% Adobe RGB, 94.62% DCI-P3, 99.67% BT.709
Input Connectors
2xHDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating, Haze 25%
Voltage
Textured black
119.4 cm x 30.3 cm x 56.8 cm
15.3 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, VCCI, BSMI, ICES-003, SEMKO, CB, CCC, TUV Ergo, PSB, DDC/CI, Lead-Free, KCC, WEEE, PSE Mark, MEPS, J-MOSS, E-Standby, KC, CECP, CEL, EPA, cETLus, RCM, CU-EAC, Ukraine, Mercury-free
3-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
114 kWh
Diagonal Size
49"
Viewable Size
48.8"
Curved Screen
Yes (1800R)
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
VA
Aspect Ratio
32:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
450 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 70 Hz
Horizontal Refresh Rate
30 - 230 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Polish, Finnish, Russian, Dutch, Greek, Turkish, Japanese, Korean
Picture by picture, Sync on Green, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, SmartUniformity, Quad & Dual Windows PBP, Adaptive-Sync technology, EasyRead, sRGB Mode, Windows 10 Hello
Textured black
119.4 cm x 30.3 cm x 56.8 cm - with stand
15.3 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort (HDCP) , 2 x HDMI (HDCP) , USB-C with Power Delivery (power up to 90W) , USB 3.1 upstream (Type B) , USB 3.1 downstream with Battery Charging 1.2 (Type A) , 2 x USB 3.1 downstream (Type A) , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+10
Swivel Angle
40
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
HDMI cable , DisplayPort cable , USB-A to USB-B cable , USB-C cable , USB-C to USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
52 W
52 kWh/1000h
Power Consumption HDR (On mode)
94 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 119.4 cm - depth: 30.3 cm - height: 56.8 cm - weight: 15.3 kg , Without stand - width: 119.4 cm - depth: 15.6 cm - height: 36.9 cm - weight: 11 kg
Shipping Width
130.8 cm
Shipping Depth
38.4 cm
Shipping Height
55.3 cm
Shipping Weight
21.48 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
20 - 80%
Diagonal Size: 49in
Response Time: 5ms
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Philips
Price Range Ex VAT: £750 - £1000
