Philips Brilliance P-line 349P7FUBEB 34" 3440x1440 4ms HDMI DisplayPort Curved LED Monitor
Quicklinx: F722WS00 Mfr#: 349P7FUBEB/00
See more and do more with the Philips Brilliance 34" curved ultra-wide display. A crystal-clear wide Quad HD curved display puts you at the centre of the desktop. All-in-one USB-C and a height-adjustable stand make for the ultimate set-up.
  • LowBlue Mode
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Ultra-narrow Border
    The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display.
  • Ultra Wide-Color Technology
    Ultra Wide-Color Technology delivers a wider spectrum of colours for a more brilliant picture. The Ultra Wide-Color wider"colour gamut" produces more natural-looking greens, vivid reds and deeper blues. Bring media entertainment, images and even productivity more alive with vivid colours from Ultra Wide-Color Technology.
  • Curved display design
    Desktop monitors offer a personal user experience, which suits a curved design very well. The curved screen provides a pleasant yet subtle immersion effect, which focuses on you at the centre of your desk.
  • MultiView technology
    With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • UltraWide CrystalClear images
    These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
  • USB-C Docking
    The new USB 3.1 Type-C cable with features a slim and reversible connector and offers easy one-cable docking. With USB 3.1 you get the fastest data speeds, 20 times as fast as USB 2.0, allowing you to transfer data from a HDD to your PC faster than ever. Simplify by connecting all your peripherals to your monitor as a dock with one cable to the notebook, including high resolution video output from your PC to monitor. Additionally, USB-C with power delivery even allows you to power and charge your notebook from the monitor, eliminating the need for extra power cables.
  • Compact Ergo Base
    The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
  • 100 Hz fast refresh
    For gaming and video performance, you demand display with lag-free, ultra-smooth images. This Philips display redraws the screen image up to 100 times per second, much faster than a standard display. A lower frame rate can make enemies appear to jump from spot to spot on the screen, making them difficult targets to hit. With a 100-Hz frame rate, you get those critical missing images on the screen, showing enemy movement in ultra-smooth motion so you can easily target them.
Philips Brilliance P-line 349P7FUBEB - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
113 kWh
Power Consumption (On mode)
77 W
Curved Screen
USB 3.0 hub, USB PD 60 Watt
Panel Type
MVA
Aspect Ratio
21:9
Native Resolution
UWQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
117.3% sRGB, 99.8% NTSC
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, Haze 25%
Voltage
Silver, textured black
81 cm x 31.1 cm x 62.1 cm
9.6 kg
Plug and Play, TUV, GS, SEMKO, CB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, MEPS, RCM, CU-EAC
3-year warranty
Display Type
Energy Class
Class C
113 kWh
Diagonal Size
34"
Curved Screen
Yes (1800R)
Built-in Devices
USB 3.0 hub
USB Power Delivery
60 Watt
Panel Type
MVA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Pixel Per Inch
109.68
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
23 - 102 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Picture by picture, Sync on Green, Compact Ergo Base, MultiView, Crystal Clear, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, Adaptive-Sync technology, USB-C Docking, Narrow Border Display, Picture-in-Picture
81 cm x 31.1 cm x 62.1 cm - with stand
9.6 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DisplayPort , USB-C (power up to 60W) , HDMI , 2 x USB 3.0 (Type A) , Audio line-in , Headphones , USB 3.0 (fast charging)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
340
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C cable , 1 x USB-C to USB-A cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
MTBF
50,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
77 W
Power Consumption (Typical)
67.09 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 81 cm - depth: 31.1 cm - height: 62.1 cm - weight: 9.6 kg , Without stand - width: 81 cm - depth: 9.8 cm - height: 36.9 cm - weight: 6.6 kg
Shipping Width
94.4 cm
Shipping Depth
22.4 cm
Shipping Height
57.8 cm
Shipping Weight
14.88 kg
Limited warranty - 3 years
20 - 80%
