Philips Brilliance P-Line 346P1CRH 34" 3440x1440 4ms HDMI DisplayPort USB-C Curved LED Monitor
Quicklinx: FR9RWS00 Mfr#: 346P1CRH/00
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: USB-C, DisplayPort, HDMI
More than 50 In Stock
£377.56 ex VAT
£453.07 inc VAT
The Philips Brilliance curved WQHD display with DisplayHDR 400 gives crisp, outstanding visuals. USB-C and a secure pop-up webcam with Windows Hello increase your productivity.
CrystalClear images with UltraWide QHD 3440 x 1440 pixels
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Built-in USB-C docking station
This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time.
Built-in KVM switch to easily switch between sources
With the MultiClient Integrated KVM switch, you can control two separate PCs with one monitor-keyboard-mouse setup. A convenient button allows you to quickly switch between sources. Handy with setups that require dual PC computing power or sharing one large monitor to show two different PCs.
Securely sign in with pop-up webcam with Windows Hello™
Phillips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello™ facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
DisplayHDR 400 for more lifelike colourful visuals
VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike, other "HDR-compatible" screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and peak brightness up to 400 nits, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
MultiView enables simultaneous dual connect and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • Secure sign-in with pop-up webcam
    Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • DisplayHDR 400 for more lifelike and outstanding visuals
    VESA-certified DisplayHDR 400 delivers a significant step up from normal SDR displays. Unlike other'HDR-compatible' screens, true DisplayHDR 400 produces astonishing brightness, contrast and colours. With global dimming and minimum 400 nits of brightness, images come to life with notable highlights while featuring deeper, more nuanced blacks. It renders a fuller palette of rich new colours, delivering a visual experience that engages your senses.
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • MultiView enables simultaneous dual connection and view
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
  • LowBlue Mode for easy-on-the-eyes productivity
  • Less eye fatigue with Flicker-Free technology
  • Built-in KVM switch to easily switch between sources
  • Built-in USB-C docking station
Philips P-line 346P1CRH - LED monitor - curved - 34" - HDR
LED-backlit LCD monitor - 34"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/416787
Energy Class
Class F
Power Consumption (On mode)
31 W
Curved Screen
Microphone, KVM Switch, 2.0 megapixel camera, USB 3.2 Gen 2 hub, USB PD 90 Watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.23175 mm
Brightness
500 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
HDR Capable
DisplayHDR 400
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
120% sRGB (CIE 1976), 88% Adobe RGB (CIE 1976), 98% NTSC (CIE 1976)
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating, Haze 25%
Voltage
Black texture
80.7 cm x 25 cm x 60.1 cm
11.65 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, SEMKO, CB, CCC, TUV Ergo, DDC/CI, RoHS, CEL, EPA, cETLus, RCM, CU-EAC, DisplayPort 1.4, HDCP 2.2
Display Type
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
34"
Curved Screen
Built-in Devices
USB Power Delivery
90 Watt
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.23175 mm
Pixel Per Inch
110
Brightness
500 cd/m²
Contrast Ratio
HDR Certification
DisplayHDR 400
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture in picture, picture by picture, Compact Ergo Base, PowerSensor, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, SmartUniformity, Adaptive-Sync technology, LightSensor, EasyRead, Windows 10 Hello
Black texture
80.7 cm x 25 cm x 60.1 cm - with stand
11.65 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
Input
Microphone
DisplayPort , HDMI , USB-C 3.2 Gen 2 upstream (power up to 90W) , DisplayPort output , USB upstream (Type B) , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+25
Swivel Angle
360
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), PVC free, lead free, DisplayPort Alt Mode, mercury free, reversible USB-C plug connects, 90W power delivery
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C to USB-A cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31 W
31 kWh/1000h
Power Consumption HDR (On mode)
66.5 kWh/1000h
Power Consumption (Typical)
34.1 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 80.7 cm - depth: 25 cm - height: 60.1 cm - weight: 11.65 kg , Without stand - width: 80.7 cm - depth: 11 cm - height: 36.7 cm - weight: 7.95 kg
Shipping Width
93 cm
Shipping Depth
28.2 cm
Shipping Height
52.5 cm
Shipping Weight
15.86 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 34in
Response Time: 4ms
Interfaces: USB-C
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Philips
