Philips Brilliance P-line 328P6AUBREB 32" LED Monitor
Quicklinx: DBJZWS00 Mfr#: 328P6AUBREB/00
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: USB-C, VGA (HD-15), DisplayPort, HDMI
£372.50 ex VAT
£447.00 inc VAT
The Philips Brilliance monitor with HDR delivers a wider range of color and brilliance for the most life-like images. With an expansive crystal-clear QHD IPS display, see the big picture with all the details.
  • Power and re-charge compatible notebook from the monitor
    This monitor features a built-in USB-C connector that meets USB Power Delivery standard. With intelligent and flexible power management, you can now power up and/or re-charge your compatible* Notebook directly from the Monitor using a single USB-C cable.
  • View Crystalclear QHD 2560 x 1440 images
    These Philips screens deliver CrystalClear, Quad HD 2560 x 1440 or 2560 x 1080 pixel images. Utilising high-performance panels with high-density pixel count, enabled by high-bandwidth sources like USB-C, Displayport, HDMI and Dual-link DVI, these new displays will make your images and graphics come alive. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions, are using 3D graphic applications or are a financial wizard working on huge spreadsheets, Philips displays will give you CrystalClear images.
  • Pro colour standards 99% Adobe RGB, 100% sRGB
    Meeting professional industry-standard colour, this monitor offers Adobe 99% and 100% sRGB colour spectrum. The enhanced colour rendering range of Adobe RGB makes it ideal for professional photo and video editing, animation or work with colour-critical projects. You can now be confident that your colour is consistent and true to the original image.
  • 10-bit IPS technology for full colours and wide viewing angle
    This Philips monitor uses a native 10-bit wide view angle display. This enables you to view consistent and smooth images with a colour depth of 1.07 billion colours, vs an 8-bit display which is limited to only 16 million possible colours. With a suitable graphics card and appropriate software, you can now work on your colour-critical professional work with ease.
  • 100% recyclable packaging
    Philips is committed to use sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In selected models, we utilize >= 65% Post-Consumer Recycled plastics, ensuring reduction in waste. Strict adherence to RoHS standards ensure substantial reduction or elimination of toxic substances like Lead and Mercury. Our display housing is made up of PVC/BFR free material.
  • PVC-BFR free housing
    This Philips monitor housing is free from brominated flame retardant and polyvinyl chloride (PVC-BFR free)
  • Built-in USB-C docking station
    This Philips display features a built-in USB type-C docking station with power delivery. Its slim, reversible USB-C connector allows for easy, one-cable docking. Keep it simple by connecting all your peripherals, like your keyboard, mouse and your RJ-45 Ethernet cable to the monitor's docking station. Simply connect your notebook to this monitor with a single USB-C cable to watch high-resolution video and transfer super-speed data while powering up and recharging your notebook at the same time.
  • Connect your notebook with one USB-C cable
    This Philips display features a USB type-C connector with power delivery. With intelligent and flexible power management, you can power charge your compatible device directly. Its slim, reversible USB-C allows for easy, one-cable connection. You can watch high resolution video and transfer data at a super-speed, while powering up and re-charging your compatible device at the same time.
  • LowBlue Mode for easy-on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • High Dynamic Range (HDR) for more lifelike colourful visuals
    High Dynamic Range delivers a dramatically different visual experience. With astonishing brightness, incomparable contrast and captivating colour, images come to life with much greater brightness while also featuring much deeper, more nuanced darks. It renders a fuller palette of rich new colours never before seen on a display, giving you a visual experience that engages your senses and inspires emotions.
Philips Brilliance P-line 328P6AUBREB - LED monitor - 32" - HDR
LED-backlit LCD monitor - 32"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/399163
Energy Class
Class E
Energy Consumption per Year
95 kWh
Power Consumption (On mode)
39.9 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2727 mm
Brightness
450 cd/m²
Contrast Ratio
1200:1 / 50000000:1 (dynamic)
HDR Capable
HDR10
Response Time
4 ms (grey-to-grey)
Colour Support
Colour Gamut
100% sRGB, 99% Adobe RGB (CIE 1973)
Input Connectors
HDMI, VGA, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Voltage
AC 100/240 V (50/60 Hz)
Textured black
74.2 cm x 27 cm x 65.7 cm
9.7 kg
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, Lead-Free
Display Type
Energy Class
Class E
Energy Class (HDR)
Class G
95 kWh
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2727 mm
Pixel Per Inch
93
Brightness
450 cd/m²
Contrast Ratio
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, SmartUniformity, USB 3.0 Fast Charge, EasyRead
Textured black
74.2 cm x 27 cm x 65.7 cm - with stand
9.7 kg
Audio
Speakers - stereo
Output Power / Channel
3 watt
DisplayPort , HDMI , VGA , USB-C , 2 x USB 3.0 downstream , Audio line-in , Headphones , Network (RJ-45)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
340
Rotation Angle
90
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
MTBF
70,000 hour(s)
Input Voltage
39.9 W
26 kWh/1000h
Power Consumption HDR (On mode)
54.9 kWh/1000h
Power Consumption (Typical)
32.4 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 74.2 cm - depth: 27 cm - height: 65.7 cm - weight: 9.7 kg , Without stand - width: 74.2 cm - depth: 6.3 cm - height: 43.8 cm - weight: 6.74 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
Diagonal Size: 32in
Response Time: 4ms
Interfaces: USB-C
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Philips
