The Philips LED display with webcam helps you collaborate and communicate, saving your time and money.
PowerSensor
PowerSensor is a built-in "people sensor" that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 80 percent and prolonging monitor life. -
AMVA LED display
Philips AMVA LED display uses a multi-domain vertical alignment technology which gives you super-high static contrast ratios for extra vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web-browsing, movies, gaming, and demanding graphical applications. Its optimized pixel management technology gives you 178/178 degree extra wide viewing angle, resulting in crisp images even in 90 degree pivot mode. -
Webcam
Embedded webcam and microphone enables you to view and communicate with your colleagues and clients. This simple solution allows you to collaborate and share, saving precious time and travel related costs. -
DisplayPort
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 meter cables and 10.8 Gbps data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates - making DisplayPort the best choice for not only general office or home use, but also for the demanding gaming and movies, video editing and more. It also keeps interoperability in mind via use of various adapters. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base's people-friendly height, swivel, tilt and rotation angle adjustments position the monitor for maximum comfort that can ease the physical strains of a long workday; cable management reduces cable clutter and keeps the workspace neat and professional. -
3 ports USB 2.0 hub
USB hub allows user to conveniently connect their plug and play multimedia devices such as USB memory devices, camera, portable HDD, Web camera, PDA, printer and many other devices which has USB connection available. The conveniently located USB 2.0 hub on the monitor allows USB 2.0 signals to pass thru to the computer. Note that many devices like cameras and HDD may need to be powered on independently, as they have higher power requirements than the monitor USB Hub can provide. -
Built-in stereo speakers
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design. -
Low bezel-to-table height
The Philips monitor, thanks to its advanced SmartErgoBase, can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows for users with greatly different heights to use the monitor in their preferred angle and height settings, helping them reduce fatigue and strain. -
TCO Edge
TCO Edge certification is given to products which go beyond existing eco-labeling programs. Over and above standard TCO requirements, it further mandates that the product uses minimum 65% of post consumer recycled plastics, is energy efficient, uses minimal hazardous materials, has 100% recyclable packaging, and is designed for easy recycling amongst other requirements. -
Zero power consumption
At the flick of the 0 watt hard switch which is conveniently located at the back, you can completely cut-off your monitor from AC power. This results in zero power consumption reducing your carbon footprint even further.
- Philips Brilliance P-line 241P4QPYKES - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Stereo speakers, USB Hub, 2.0 megapixel camera
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 5000:1 / 20000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 56.5 cm x 22 cm x 51.8 cm
- 6.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- Panel Type
- A-MVA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Vertical Refresh Rate
- 75 Hz
- Horizontal Refresh Rate
- 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Controls & Adjustments
- Volume, brightness
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
- Sync on Green, sRGB colour management, HDCP, Lead-free, Eco-Mode, PowerSensor, SmartContrast, SmartImage
- Black, silver
- 56.5 cm x 22 cm x 51.8 cm - with stand
- 6.4 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1.5 Watt
- VGA , DVI-D , 3 x USB 2.0 , Audio line-in , Headphones , DisplayPort
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 130
- Rotation Angle
- 90
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- MTBF
- 30,000 hour(s)
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 23.4 Watt
- Power Consumption Stand by / Sleep
- 0.1 Watt
- OS Required
- Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Dimensions & Weight Details
- With stand - width: 56.5 cm - depth: 22 cm - height: 51.8 cm - weight: 6.4 kg , Without stand - width: 56.5 cm - depth: 5.5 cm - height: 35.2 cm - weight: 4.2 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
