Philips Brilliance 17S1SB - LCD monitor - 17"
Quicklinx: 7NPBWS00 Mfr#: 17S1SB/00
With features like SmartImage, SmartContrast, SmartControl and TrueVision, the energy efficient 17S1 business display increases your productivity.
  • SmartImage
    SmartImage is an exclusive, leading edge Philips technology that analyzes the content displayed on your screen. Based on a scenario you select, SmartImage dynamically enhances the contrast, color saturation and sharpness of images and videos for ultimate display performance - all in real time with the press on a single button.
  • Adjustable tilt
    Adjustable tilt is backward and forward movement of a screen on its base to achieve custom positioning for an ideal viewing angle and more comfort for people who spend long hours working on the computer.
  • Eco-friendly materials
    With sustainability as a strategic driver of its business, Philips is committed to use eco-friendly materials across its product range. Lead-free materials are used across the range. All body plastic parts, metal chassis parts and packing material uses 100% recyclable material. 50% reduction in mercury content in lamps has been achieved. They strictly adhere to RoHs standards which ensure that all hazardous material is removed, and only environmentally friendly material is used.
  • Energy Star 5.0
    Energy Star is a US EPA sponsored energy efficiency program also adopted by many other countries. Energy Star certification ensures that you are buying a product which meets the latest power efficiency standards which operates with maximum power efficiency at all operational levels. Philips monitors are certified for Energy Star 5.0 specifications and meet or exceed the standard. For example, in sleep mode Energy Star 5.0 requires less than 1watt power consumption, whereas Philips monitors consume less than 0.5watts.
LCD monitor - 17"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
800:1 / 25000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Black texture
38.9 cm x 17.9 cm x 36.7 cm
3.45 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SEMKO, TUV Ergo, DDC/CI, RoHS
3-year warranty
Display Type
LCD monitor / TFT active matrix
Diagonal Size
17"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Controls & Adjustments
Brightness
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish
Sync on Green, HDCP, SmartContrast, SmartImage, TrueVision
Black texture
3.45 kg
VGA , DVI-D
Mechanical
Tilt
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
MTBF
50,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption Stand by / Sleep
0.5 Watt
Included Software
Philips SmartControl II
Microsoft Windows 98, Microsoft Windows 2000, Apple MacOS X, Microsoft Windows XP, Microsoft Windows Vista
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
20 - 80%
