Expand your experience with this 34" UltraWide Philips display. See the big picture with all the details with this large UltraWide screen. Multitask like never before with multiple features at once.
Built-in stereo speakers
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design. -
SmartErgoBase
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional. -
Low bezel-to-table height
Thanks to its advanced SmartErgoBase, the Philips monitor can be lowered down almost to desk level for a comfortable viewing angle. Low bezel-to-table height is the perfect solution if you use bifocals, trifocals or progressive lens glasses for your computing work. Additionally, it allows users of different heights to use the monitor at their preferred angle and height settings, helping them to reduce fatigue and strain. -
HDMI Ready
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras). -
IPS technology
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times. -
USB 3.0 super speed
Super Speed USB 3.0 deploys a 5.0 Gbit/s transfer rate, which is about 10 times faster than USB 2.0 standard, significantly reducing data transfer time and saving you time and money. With more bandwidth, super-speed transfer rates, better power management and superior overall performance, USB 3.0 sets the global standard, allowing you to use large-capacity storage devices. Sync-N-Go technology ensures that you no longer have to wait for bandwidth to be freed up. Your investment in USB 2.0 devices is protected as it is backwards compatible. -
UltraWide CrystalClear images
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images. -
MultiView technology
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking. -
SmartUniformity
Fluctuations in brightness and colour on LCD screens are a common phenomenon. Philips' SmartUniformity mode delivers accurate images in terms of brightness; which is crucial for photography, design and printing. With a colour metric to assess colour accuracy, this mode is calibrated to meet average luminance uniformity of more than 95%. Selecting this mode will produce uniform and accurate images. -
Ultra-Narrow Bezel
Utilising the latest technology panels, the new Philips displays are designed with a minimalistic approach by limiting the outer bezel thickness to about 2.5 mm. Combined with an in-panel black matrix strip of around 9 mm, the overall bezel dimensions are reduced significantly, minimising distractions and maximising viewing size. Especially suited to multi-display or tiling setups like gaming, graphics design and professional applications, the Ultra-narrow bezel display gives you the feeling of using one large display.
- Philips BDM3470UP - LED monitor - 34"
- LED-backlit LCD monitor - 34"
- Energy Class
- Class C
- Energy Consumption per Year
- 92 kWh
- Power Consumption (On mode)
- 63 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- QHD 3440 x 1440
- Pixel Pitch
- 0.232 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- 1000:1 / 40000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Input Connectors
- HDMI, DVI, DisplayPort, VGA
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 82.8 cm x 27 cm x 62.7 cm
- 9.46 kg
- Environmental Standards
- ENERGY STAR Qualified
- EPA 6.0
- Display Type
- Energy Class
- Class C
- 92 kWh
- Diagonal Size
- 34"
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- QHD 3440 x 1440
- Pixel Pitch
- 0.232 mm
- Brightness
- 320 cd/m²
- Contrast Ratio
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- SmartResponse, MultiView, SmartContrast, Mobile High-Definition Link (MHL)
- Black
- 82.8 cm x 27 cm x 62.7 cm - with stand
- 9.46 kg
Audio
- Speakers - internal
- VGA , DVI , HDMI , DisplayPort , 2 x USB 2.0 , 2 x USB 3.0 , Audio line-in , Headphones
Mechanical
- Height Adjustment
- 180 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
- EPA 6.0
- Power Supply
- Internal
- Input Voltage
- 63 W
- Power Consumption (Typical)
- 40.8 Watt
- Power Consumption Stand by
- 0.4 Watt
- Power Consumption Sleep
- 0.3 Watt
- On / Off Switch
- Included Software
- Philips SmartControl Premium
- Dimensions & Weight Details
- With stand - width: 82.8 cm - depth: 27 cm - height: 62.7 cm - weight: 9.46 kg , Without stand - width: 82.8 cm - depth: 5.8 cm - height: 37.8 cm
Sustainability Information
- ENERGY STAR Certified
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £30.34 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
