Philips BDL3260EL 32" 1920x1080  25ms VGA DVI HDMI DP LED LFD
Quicklinx: BNHJWS00 Mfr#: BDL3260EL/00
  • 1080p
With this energy efficient Signage Solution display, you will enjoy all the benefits of state-of-the-art connectivity and content management possibilities while being ensured that remote management safeguards the lowest cost of ownership.
  • Manage and control your network remotely via SmartControl
    SmartControl software suite lets you remotely control and manage your network of displays via RJ45 and RS232C. Easy identify your displays and fine-tune all display settings including resolution, brightness, contrast, video wall configurations and cloning of your settings over your complete network.
  • Free and easy-to-use content management with SmartCMS
    Free and easy-to-use content management system that works exclusively with Philips Sigage Solutions displays to manage your digital signage content. With SmartCMS you can create and schedule your own content over 24 hours every day. Simply create your network, design your content, schedule your playlist and you are ready to play!
  • Connect and control your content via the cloud with HTML5
    Connect and control your content via the cloud with the integrated HTML5 browser. Design your signage content online and connect it with a display or with your complete network. Simply plug in a RJ45 internet cable for network connection, connect the display with the dedicated url-address and you are ready to play your cloud based content.
  • Keep your content up and running with FailOver
    Keeping your content up and running is critical for demanding commercial applications. While it is unlikely you will face a content disaster, FailOver provides 24/7 protection with a revolutionary technology that plays back-up content on screen in the event of a media player failure. FailOver automatically kicks in when the primary input fails. Simply select a primary input connection and a FailOver connection and you are ready for instant protection.
  • Schedule what you want, when you want with SmartPlayer
    Save your Digital Signage content (video, audio, pictures) on your USB and plug into your display & enjoy your own created playlists 24 hours a day, 7 days a week.
  • SmartPower for energy saving
    The backlight intensity can be controlled and pre-set by the system to reduce the power consumption by up to 50%, which saves substantially on energy costs.
  • Designed for 24/7 operation
    Because business never sleeps, the signage displays are designed for 24/7 use. Taking advantage of superior components to ensure a higher level of quality, you can count on this range of models for complete around-the-clock reliability.
  • Connect your display and start sharing with DLNA
    Simply share & stream content from your mobile device or media player to your display with all DLNA compliant media devices. Connect each display with an ethernet cable and manage your content real time within your local network. Simply connect your display and start sharing.
  • Full HD LED technology for brilliant images
    White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of LCD backlight, resulting in super high contrast ratio. It also gives superior color reproduction thanks to consistent brightness across the screen.
  • IPS wide view technology for image and color accuracy
    Philips IPS displays uses an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle - even in portrait mode. IPS displays gives you remarkably crisp images with vivid colors, especially suitable for professional video wall and menu board applications which demand color accuracy and consistent brightness at all times.
Philips BDL3260EL E-Line - 32" Class (31.55" viewable) LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
32"
Diagonal Size
31.55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Input Video Formats
1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 576/50p, 1080/50p, 1080/60p, 480/60i, 576/50i
Max Number of Screens
100
Video Interface
Component, composite, HDMI
HDMI Ports Qty
2 ports
LAN
PC Interface
DVI, VGA (HD-15), DisplayPort
HDCP Compatible
IPS
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage, HTML5 support
Settings Cloning Capability
Speaker System
2 speakers
USB
Remote control, batteries
Voltage
AC 100/230 V (50/60 Hz)
48.57 Watt
Power Consumption Stand by
0.3 Watt
75.02 cm x 6.9 cm x 44.46 cm
11.4 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
48.57 Watt
Diagonal Class
32"
Diagonal Size
31.55"
Commercial Use
Series
E-Line
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI Ports Qty
2 ports
PC Interface
HDCP Compatible
Modes
Portrait mode, landscape mode
75.02 cm
6.9 cm
44.46 cm
11.4 kg
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
16.7 million colours
Image Contrast Ratio
1300:1
Dynamic Contrast Ratio
500000:1
Brightness
400 cd/m²
Widescreen Modes
16:9
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.36 x 0.36mm
Pull-Down Compensation
3:2, 2:2
Response Time
25 ms
Display Menu Language
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Polish, Russian, Spanish, Turkish, Arabic, Japanese
Backlight Life
60,000 hour(s)
Comb Filter
3D digital
Commercial Features
Dynamic Contrast, 3D MA deinterlacing, Smart Insert, Smart Control, Motion Compensation, SmartCMS
Video Wall
100
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
100 x 100 mm, 400 x 200 mm
Video Features
Input Video Formats
Supported Computer Resolutions
1366 x 768, 1920 x 1200 (WUXGA), 1024 x 768 (XGA), 640 x 480 (VGA), 800 x 600 (SVGA), 1280 x 768 (WXGA), 1360 x 768, 1920 x 1080, 1440 x 900, 1280 x 800
Media Player
Supported Video Formats
MPEG-4, WMV, MKV, VOB, TS, M2TS, M4V, MPG, MPEG, MTS
Supported Audio Formats
MP3, WMA, WAV, AAC, AIFF, LPCM, M4A
Supported Pictures Formats
BMP, JPG, GIF
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
Functionality
WEB browsing
LAN
DLNA
Connector Type
DisplayPort input , 2 x HDMI input , DVI-D input , VGA input , USB , Component video input , Composite video input , DisplayPort output , DVI-I , VGA output , Audio line-in , Audio line-in , Audio line-out , Speakers output , LAN , Serial , Remote control
Batteries
VGA cable , Serial cable
FCC Class B certified, UL, VCCI, C-Tick, BSMI, GOST, cUL, CB, CCC, RoHS, PSE Mark, J-MOSS
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.3 Watt
Smart power
Limited warranty - 3 years
20 - 80%
