Philips B Line 345B1C LED Curved 34" 3440x1440 HDMI USB 4ms
Quicklinx: GNGBWS00 Mfr#: 345B1C/00
Diagonal Size: 34in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£212.00 ex VAT
£254.40 inc VAT
The Philips B line 34" curved UltraWide display gives a wrap-around view of your work. A crystal-clear WQHD display and ergonomic stand design make for optimal working conditions. Eye comfort features with TUV certification to reduce eye fatigue.
CrystalClear images with UltraWide QHD 3440 x 1440 pixels
These Philips screens deliver Crystal Clear, UltraWide Quad HD 3440 x 1440 pixel images. Utilising high-performance panels with high-density pixel count and 178/178 wide viewing angles, these new displays will make your images and graphics come alive. The UltraWide 21:9 format enables more productivity with more room for side-by-side comparisons and more viewable spreadsheet columns. Whether you are a demanding professional requiring extremely detailed information for CAD-CAM solutions or a financial wizard working on huge spreadsheets, Philips displays deliver Crystal Clear images.
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
Tilt, swivel and height-adjust for an ideal viewing position
The Compact Ergo Base is a people-friendly Philips monitor base that tilts, swivels and height-adjusts so each user can position the monitor for maximum viewing comfort and efficiency.
DisplayPort connection for maximum visuals
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
VA display delivers awesome images with wide viewing angles
The Philips VA LED display uses an advanced multi-domain vertical alignment technology that gives you super-high static contrast ratios for extra-vivid and bright images. While standard office applications are handled with ease, it is especially suitable for photos, web browsing, films, gaming and demanding graphical applications. Its optimised pixel management technology gives you a 178/178 degree extra-wide viewing angle, resulting in crisp images.
EasyRead mode for a paper-like reading experience
MultiView enables simultaneous dual connection and view
With the ultra-high resolution Philips MultiView display, you can now experience a world of connectivity. MultiView enables active dual connect and view so that you can work with multiple devices like a PC and notebook simultaneously, for complex multitasking.
  • HDMI ensures universal digital connectivity
  • Tilt, swivel and height-adjust for an ideal viewing position
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • LightSensor for the perfect brightness with minimal power
  • DisplayPort connection for maximum visuals
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • Less eye fatigue with Flicker-Free technology
  • LowBlue Mode for easy-on-the-eyes productivity
  • CrystalClear images with UltraWide QHD 3440 x 1440 pixels
  • VA display delivers awesome images with wide viewing angles
  • MultiView enables simultaneous dual connection and view
  • Effortlessly smooth action with Adaptive-Sync technology
Philips 345B1C - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/420503
Energy Class
Class F
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
31.4 W
Curved Screen
USB 3.2 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
WQHD 3440 x 1440 at 100 Hz
Pixel Pitch
0.232 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
100% NTSC (CIE 1976), 119% sRGB (CIE 1931), 90% Adobe RGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 2H Hard Coating, Haze 25%
Voltage
Black texture
80.7 cm x 25 cm x 60.1 cm
11.32 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Silver
Plug and Play, FCC Class B certified, SEMKO, DDC/CI, RoHS, Lead-Free, ISO 9241-307, TUV Bauart, EPA, cETLus, CU-EAC, DisplayPort 1.2, BFR-free, HDCP 2.2, HDCP 1.4, PVC-free
Display Type
Energy Class
Class F
79 kWh
Diagonal Size
34"
Curved Screen
Yes (1500R)
Built-in Devices
USB 3.2 hub
Panel Type
VA
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.232 mm
Pixel Per Inch
110
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Picture by picture, PowerSensor, MultiView, SmartImage, Low Blue Light Mode, Flicker Free technology, Mercury free, SmartUniformity, Adaptive-Sync technology, LightSensor, EasyRead, sRGB Mode, Picture-in-Picture
Black texture
80.7 cm x 25 cm x 60.1 cm - with stand
11.32 kg
Audio
Speakers - stereo
Output Power / Channel
5 watt
DisplayPort (HDCP) , 2 x HDMI (HDCP) , 3 x USB 3.2 downstream , USB 3.2 downstream (quick charging) , USB upstream , Headphones
Mechanical
Tilt Angle
-5/+30
Swivel Angle
360
Height Adjustment
180 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
31.4 W
31.4 kWh/1000h
Power Consumption (Typical)
45 watt
Power Consumption Stand by
0.3 watt
Power Consumption (Off Mode)
0.3 watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 80.7 cm - depth: 25 cm - height: 60.1 cm - weight: 11.32 kg , Without stand - width: 80.7 cm - depth: 11 cm - height: 36.7 cm - weight: 7.62 kg
Shipping Width
93 cm
Shipping Depth
28.2 cm
Shipping Height
52.5 cm
Shipping Weight
15.05 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
7.0
20 - 80%
Diagonal Size: 34in
Response Time: 5ms
Interfaces: HDMI
Brand: Philips
