Philips B Line 272B1G 27" LED monitor 1920 x 1080 Full HD
Quicklinx: G6F8WS00 Mfr#: 272B1G/00
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15), DVI, DisplayPort
Hurry, only 1 left in stock!
£168.84 ex VAT
£202.60 inc VAT
Super energy efficient
The eco-friendly Philips 27" monitor is designed for sustainable productivity. Super-energy-efficient design delivers a new level of power savings. PowerSensor and LightSensor further reduce energy use while delivering crisp visuals.
Super-energy-efficient design for maximum power savings
Using the new energy saving design with a super-efficient power supply, this monitor achieves a higher energy class, while giving excellent performance. The power-efficient feature uses new LED backlight technology which maintains brightness and colour using significantly less energy; this makes a big difference when using many monitors or even just one.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
Zero power consumption with 0-watt hard switch
At the flick of the 0-watt hard switch, which is conveniently located at the back of the monitor, you can completely cut off your monitor from AC power. This results in zero power consumption, reducing your carbon footprint even further.
Eco-friendly materials meet major international standards
Philips is committed to using sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In selected models, we use up to 85% post-consumer recycled plastics. Strict adherence to RoHS standards ensures a substantial reduction or elimination of toxic substances like lead and mercury, which have been eliminated completely in monitors with an LED backlight.
100% recycled packing material
100% recycled packing material for less environmental impact.
  • Super energy efficient design for maximum power savings
    Using new energy saving design with a super-efficient power supply, this monitor achieves a higher energy class, while giving excellent performance. Power efficient feature uses a new LED backlight technology which maintains brightness and color using significantly less energy; makes a big difference when using many monitors or even just one.
  • Eco-friendly materials meet major international standards
    Philips is committed to use sustainable, eco-friendly materials across its monitor range. All body plastic parts, metal chassis parts and packing materials use 100% recyclable materials. In selected models we utilize up to 85% post-consumer recycled plastics. Strict adherence to RoHS standards ensures substantial reduction or elimination of toxic substances.
  • 100% Recyclable packing material
    100% Recyclable packing material for less environmental impact.
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • LowBlue Mode for easy on-the-eyes productivity
    Studies have shown that just as ultra-violet rays can cause eye damage, shortwave length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
  • Zero power consumption with 0 watt hard switch
    At the flick of the 0 watt hard switch which is conveniently located at the back, you can completely cut-off your monitor from AC power. This results in zero power consumption reducing your carbon footprint even further
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if user is present and automatically reduces monitor brightness when user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • LightSensor for the perfect brightness with minimal power
    LightSensor uses a smart sensor to adjust the picture brightness depending on the room light conditions for the perfect picture with minimal power usage.
  • TUV Eye Comfort certified to reduce eye fatigue
Philips B Line 272B1G - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/388610
Energy Class
Class B
Power Consumption (On mode)
14 W
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.3114 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
76% (NTSC 1976), 98% sRGB (CIE 1931)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
61.3 cm x 20.5 cm x 53.7 cm
5.74 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, Lead-Free, EPA, CU-EAC, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free
3-year warranty
Display Type
Energy Class
Class B
Diagonal Size
27"
Built-in Devices
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, LightSensor, EasyRead, sRGB Mode
Black texture
61.3 cm x 20.5 cm x 53.7 cm - with stand
5.74 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , USB upstream (Type B) , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+35
Swivel Angle
360
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
14 W
11 kWh/1000h
Power Consumption (Typical)
14.7 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 61.3 cm - depth: 20.5 cm - height: 53.7 cm - weight: 5.74 kg , Without stand - width: 61.3 cm - depth: 5.1 cm - height: 36.6 cm - weight: 4.13 kg
Shipping Width
70 cm
Shipping Depth
21.6 cm
Shipping Height
45.6 cm
Shipping Weight
9.12 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
20 - 80%
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DVI
Interfaces: DisplayPort
Brand: Philips
