Philips B Line 242B1TC LED 24" 1920x1080 4ms HDMI VGA USB DVI
Quicklinx: GGPHWS00 Mfr#: 242B1TC/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: HDMI, VGA (HD-15), DisplayPort
£251.98 ex VAT
£302.37 inc VAT
A durable, anti-glare touchscreen for flexible use, with articulating stand to angle as you need. Advanced In-Cell Touch (AIT) offers a slimmer look, superior touch sensitivity for quick response, outstanding and clearer visibility.
SmoothTouch display for natural, fluid touch response
This Philips display uses Projected capacitive 10-point touch technology for fluid response. You can fully utilise the new capabilities of touch-based applications and bring your older applications to life. Touch-type with 10 fingers or play exciting interactive games with your friends. Collaborate with colleagues interactively at work or school environment and increase your productivity and efficiency.
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
HDMI ensures universal digital connectivity
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
DisplayPort connection for maximum visuals
DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates — making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
EasyRead mode for a paper-like reading experience
SmartStand with adjustable angles, boosts productivity
Philips SmartStand allows for flexible adjustment of the screen. Its Z-type structure with smooth tilt, height adjustment and folding capabilities enables you to use it in various ergonomic positions. You can set the stand in upright position for better touch control or recline it backwards, making it easy for you to draw or annotate. It even allows you to put the screen almost flat on the table for some applications when required.
  • DisplayPort connection
    DisplayPort is a digital link from PC to monitor without any conversion. With higher capabilities than DVI standard, it is fully capable to support up to 15 metre cables and 10.8 Gbps/sec data transfer. With this high performance and zero latency, you get the fastest imaging and refresh rates- making DisplayPort the best choice for not only general office or home use, but also for the more demanding gaming and films, video editing and more. It also keeps interoperability in mind via the use of various adapters.
  • SmoothTouch
  • SmartStand
  • HDMI Ready
Philips 242B1TC - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/430411
Energy Class
Class E
Power Consumption (On mode)
18 W
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
102% sRGB, 83% Adobe RGB, 88% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, tilt, Fold
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
54 cm x 22.7 cm x 40.3 cm
6.67 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, TUV Ergo, DDC/CI, RoHS, CU-EAC, TUV Eye Comfort certified, EAEU RoHS
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
Sync on Green, Lead-free, SmartContrast, SmartImage, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Mercury free, Adaptive-Sync technology, EasyRead, sRGB Mode
Black texture
54 cm x 22.7 cm x 40.3 cm - with stand
6.67 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
Touchscreen
VGA , DisplayPort 1.2 , HDMI , USB 3.2 upstream , 2 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones
Mechanical
Height, tilt, Fold
Tilt Angle
-5/+90
Height Adjustment
183 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-A to USB-B cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
18 W
18 kWh/1000h
Power Consumption (Typical)
15.6 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand - width: 54 cm - depth: 22.7 cm - height: 40.3 cm - weight: 6.67 kg , Without stand - width: 54 cm - depth: 5.1 cm - height: 32.3 cm - weight: 3.34 kg
Shipping Width
62 cm
Shipping Depth
14 cm
Shipping Height
42 cm
Shipping Weight
9.01 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
20 - 80%
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Interfaces: DisplayPort
Brand: Philips
