Philips B Line 242B1H/00 23.8" 1920x1080 4ms VGA HDMI USB
Quicklinx: FZ2JWS00 Mfr#: 242B1H/00
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), DisplayPort, DVI, HDMI
40 In Stock
£167.88 ex VAT
£201.45 inc VAT
Clear vision to get more done
This Philips monitor with a secure pop-up webcam with Windows Hello offers personalised and greater security. Loaded with features to improve productivity and sustainability. Eye comfort features with TUV certified to reduce eye fatigue.
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in 'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
LightSensor for the perfect brightness with minimal power
LightSensor uses a smart sensor to adjust the picture brightness depending on the light conditions in the room for the perfect picture with minimal power usage.
IPS technology for full colours and wide viewing angles
IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle — even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
SmartImage pre-sets for easy optimised image settings
SmartImage is an exclusive leading edge Philips technology that analyses the content displayed on your screen and optimises your display performance. This user-friendly interface allows you to select various modes, like Office, Photo, Movie, Game, Economy etc., to fit the application in use. Based on the selection, SmartImage dynamically optimises the contrast, colour saturation and sharpness of images and videos for ultimate display performance. The Economy mode option offers you major power savings. All in real time at the touch of a single button!
Effortlessly smooth action with Adaptive-Sync technology
Gaming shouldn't be a choice between choppy gameplay or broken frames. Get fluid, artefact-free performance at virtually any frame rate with Adaptive-Sync technology, smooth quick refresh and ultra-fast response time.
Securely sign in with pop-up webcam with Windows Hello™
Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello™ facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
TUV Eye Comfort certified to reduce eye fatigue
Philips displays meet TUV Rheinland Eye Comfort standard to prevent eye strain caused by prolonged computer use. With TUV Eye Comfort certification, Philips displays ensure flicker-free, low-blue mode, no disturbing reflections, a wide viewing angle, less reduction of image quality from different angles and ergonomic stand designs for an ideal viewing experience. Keep your eyes healthy and boost work productivity.
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing.
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light.
SmartErgoBase enables user-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The user-friendly height, swivel, tilt and rotation angle adjustments of the base allow the monitor to be positioned for maximum comfort to help ease the physical strains of a long workday. In addition, cable management reduces cable clutter and keeps the workspace neat and professional.
Built-in stereo speakers for multimedia
A pair of high-quality stereo speakers built into a display device. They may be visible front firing, or invisible down firing, top firing, rear firing etc. depending on model and design.
  • PowerSensor saves up to 70% energy costs
    PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life.
  • LightSensor for the perfect brightness with minimal power
  • TUV Eye Comfort certified to reduce eye fatigue
  • SmartImage pre-sets for easy optimised image settings
  • Effortlessly smooth action with Adaptive-Sync technology
  • IPS technology for full colours and wide viewing angles
    IPS displays use advanced technology that gives you extra-wide viewing angles of 178/178 degrees, making it possible to view the display from almost any angle- even in 90-degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colours, making it ideal not only for Photos, films and web browsing, but also for professional applications that demand colour accuracy and consistent brightness at all times.
  • Secure sign-in with pop-up webcam
    Philips' innovative and secure webcam pops up when you need it and securely tucks back into the monitor when you are not using it. The webcam is also equipped with advanced sensors for Windows Hello facial recognition, which conveniently logs you into your Windows devices in less than 2 seconds, 3 times faster than a password.
  • Less eye fatigue with Flicker-Free technology
  • Built-in stereo speakers for multimedia
  • LowBlue Mode for easy-on-the-eyes productivity
  • SmartErgoBase enables user-friendly ergonomic adjustments
    The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height-adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional.
  • Designed to meet environmental standards
    Designed for sustainability and reduced operating costs, this monitor meets environmental standards. Such as: ENERGY STAR, EPEAT, TCO Certified.
Philips 242B1H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/405287
Energy Class
Class D
Power Consumption (On mode)
14 W
Microphone, 2.0 megapixel camera, USB 3.2 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
107% sRGB (CIE 1931), 91% NTSC (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
Black texture
54 cm x 20.5 cm x 50.1 cm
4.77 kg
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified
Plug and Play, FCC Class B certified, TUV GS, ICES-003, SEMKO, CB, CCC, TUV Ergo, DDC/CI, RoHS, Lead-Free, CECP, CEL, EPA, CU-EAC, DisplayPort 1.2, BFR-free, HDCP 1.4, PVC-free, Mercury-free
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 85 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Multilingual
Sync on Green, PowerSensor, SmartImage, Low Blue Light Mode, Flicker Free technology, Adaptive-Sync technology, LightSensor, EasyRead, sRGB Mode, Windows 10 Hello
Black texture
54 cm x 20.5 cm x 50.1 cm - with stand
4.77 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , USB upstream (Type B) , 3 x USB 3.2 downstream , USB 3.2 downstream (fast charging) , Audio line-in , Headphones
Mechanical
Tilt Angle
-5/+35
Swivel Angle
360
Rotation Angle
180
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-A to USB-B cable , 1 x audio cable
MTBF
70,000 hour(s)
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
14.5 Watt
Power Consumption Stand by
0.4 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Included Software
Philips SmartControl
Dimensions & Weight Details
With stand (highest position) - width: 54 cm - depth: 20.5 cm - height: 50.1 cm - weight: 4.77 kg , Without stand - width: 54 cm - depth: 5.1 cm - height: 32.3 cm - weight: 3.17 kg
Shipping Width
60 cm
Shipping Depth
19.8 cm
Shipping Height
46.5 cm
Shipping Weight
7.04 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
20 - 80%
Diagonal Size: 24in
Response Time: 4ms
Interfaces: DisplayPort
Interfaces: DVI
Interfaces: HDMI
Brand: Philips
