Simple USB-C connection and crystal-clear IPS images. The Philips B-line monitor with USB-C connector allows simple notebook docking via one cable for fast data and video to full HD IPS display, and even notebook charging.
All your connections through one USB-C cable
The new USB 3.1 Type-C cable with features a slim and reversible connector and offers easy one-cable docking. With USB 3.1 you get the fastest data speeds, 20 times as fast as USB 2.0, allowing you to transfer data from a HDD to your PC faster than ever. Simplify by connecting all your peripherals to your monitor as a dock with one cable to the notebook, including high resolution video output from your PC to monitor. Additionally, USB-C with power delivery even allows you to power and charge your notebook from the monitor, eliminating the need for extra power cables. -
Narrow border display for seamless appearance
The new Philips displays feature ultra-narrow borders which allow for minimal distractions and maximum viewing size. Especially suited for multi-display or tiling setups like gaming, graphic design and professional applications, the ultra-narrow border display gives you the feeling of using one large display. -
SmartErgoBase enables people-friendly ergonomic adjustments
The SmartErgoBase is a monitor base that delivers ergonomic display comfort and provides cable management. The base can swivel, tilt and rotate to various angles to ensure maximum comfort. The height adjustable stand guarantees the optimal viewing level, reducing the physical strains of a long workday, while cable management reduces cable clutter and keeps the workspace neat and professional. -
IPS technology for full colors and wide viewing angles
IPS displays use an advanced technology which gives you extra wide viewing angles of 178/178 degree, making it possible to view the display from almost any angle- even in 90 degree Pivot mode! Unlike standard TN panels, IPS displays gives you remarkably crisp images with vivid colors, making it ideal not only for Photos, movies and web browsing, but also for professional applications which demand color accuracy and consistent brightness at all times. -
PowerSensor saves up to 70% energy costs
PowerSensor is a built-in'people sensor' that transmits and receives harmless infrared signals to determine if the user is present and automatically reduces monitor brightness when the user steps away from the desk, cutting energy costs by up to 70 percent and prolonging monitor life. -
LowBlue Mode for easy-on-the-eyes productivity
Studies have shown that just as ultra-violet rays can cause eye damage, shortwave-length blue light rays from LED displays can cause eye damage and affect vision over time. Developed for wellbeing, the Philips LowBlue Mode setting uses a smart software technology to reduce harmful shortwave blue light. -
Less eye fatigue with Flicker-Free technology
Due to the way brightness is controlled on LED-backlit screens, some users experience flicker on their screen which causes eye fatigue. Philips Flicker-Free technology applies a new solution to regulate brightness and reduce flicker for more comfortable viewing. -
Built-in stereo speakers for multimedia
A pair of high quality stereo speakers built into a display device. It can be visible front firing, or invisible down firing, top firing, rear firing, etc depending on model and design.
- Philips B Line 241B7QUPBEB - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/393451
- Energy Class
- Class E
- Energy Consumption per Year
- 35 kWh
- Power Consumption (On mode)
- 18 W
- USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 20000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort, USB-C
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Textured black
- 54.1 cm x 25.7 cm x 52.7 cm
- 5.72 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified
- Plug and Play, FCC Class B certified, TUV GS, VCCI, ICES-003, SEMKO, TUV Ergo, DDC/CI, RoHS, Lead-Free, WEEE, EPA, cETLus, RCM, CU-EAC
- Display Type
- Energy Class
- Class E
- 35 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.0/USB-C hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, Brazilian Portuguese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean
- Sync on Green, sRGB colour management, PowerSensor, SmartResponse, SmartContrast, SmartImage, Smart Ergo base, Low Blue Light Mode, Flicker Free technology, BFR/PVC-free, Ultra Narrow Border, Mercury free, USB 3.0 Quick Charge, Wide Viewing Angle, EasyRead
- Textured black
- 54.1 cm x 25.7 cm x 52.7 cm - with stand
- 5.72 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , DisplayPort , HDMI , USB-C upstream , DisplayPort output , Audio line-in , Headphones , Network , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 350
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x USB-C cable , 1 x USB-C to USB-A cable , 1 x audio cable
- MTBF
- 70,000 hour(s)
- Input Voltage
- 18 W
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 15.4 Watt
- Power Consumption Stand by
- 0.7 Watt
- 0.3 Watt
- On / Off Switch
- Included Software
- Philips SmartControl
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 54.1 cm - depth: 25.7 cm - height: 52.7 cm - weight: 5.72 kg , Without stand - width: 54.1 cm - depth: 5.7 cm - height: 33.2 cm - weight: 3.29 kg
- Shipping Width
- 60.3 cm
- Shipping Depth
- 22.4 cm
- Shipping Height
- 49.2 cm
- Shipping Weight
- 8.94 kg
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 20 - 80%
